Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Jun 2012
    New To Buffing and Need Some Advice
    So I've had the tools to buff for a while now, and never really got around to it because I've never had the experience. I've watched some videos on here from Mike Phillips and as much as watching videos can help, it still leaves a pretty good gap if you don't have hands on experience (at least in my case it does).
    I recently bought a Black 2012 Honda CR-Z. And I noticed that there were a lot of swirls in the paint right off the bat. I know why, because Dealers usually wash cars for customers, using the same brushes FOREVER until they get too nasty to wash cars with. So I attempted to buff them out one weekend.
    I thought I was doing well enough. I could see the swirls disappearing, but my lighting situation wasn't perfect, so I couldn't see that I was just putting buffer swirls into the paint.
    I used these products:
    Porter Cable 7424 XP
    Hex Logic Orange Buffing Pad:
    SCRATCH & SWIRL REMOVER BUFFING PAD
    And V38 Optical Final Polish
    How To Use Paint Polish and A Paint Polisher for Long-Lasting Shine
    And this is basically what happened.
    I have a variety of pads, and could purchase different compounds if necessary. But if anyone could possibly lend me some advice as to get rid of the buffer swirls, I would greatly appreciate it.
    Super Member Perfections's Avatar
    Aug 2010
    Buna TX
    1,257
    Buy a jeweling pad, and try the same polish. If that polish isn't finishing down good enough, cant say as I've never used it get something like optimums finish polish, pinnacles advance finishing polish, menzerna po85rd or I think the new name is menzerna 4500.
    A passion for perfection!
    Super Member octane's Avatar
    Apr 2012
    Ottawa, Canada
    398
    Re: New To Buffing and Need Some Advice
    how many pads are you using, cleaning them on the fly every panel?
    Aug 2010
    Buna TX
    1,257
    Quote Originally Posted by octane View Post
    I usually use 2-3 pads if I'm jeweling the paint. Cleaning them on the fly after every time that pad touches the paint. Black you have to take as much precaution as you can and after every panel usually doesn't cut it.
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Definitely try a polishing pad with the V38 and you should see a big difference.
    Jun 2012
    Thanks guys, I'll make sure to do another try this upcoming weekend, and I'll post the results
    Honda paint is known to be on the soft side and this means it will haze easy with too aggressive pad or product and for sure both.
    What I see in the picture is DA Haze.
    Like others said try a softer pad and don't push too hard for the finishing passes...
    If nothing else, I've had really good luck with Menzerna polishes on softer paints...
    Jun 2012
    Thanks a lot for the advice once again! I can't wait to get back to it, super rainy today though
    SELF BANNED
    Aug 2012
    299
    Quote Originally Posted by Quatakai View Post
    Just take your time...technique is very important..Cant wait to see your before and after pics...take alot of them from different angles. Good luck
  10. #10
    Sep 2012
    This is what scares me, I have my order on its way and will try to buff my spider webs out of my new car. I hope I do not make it worse!
  1. Advice on switching from 3M to Menzerna buffing Aircraft dope
    By Ryan Johnson in forum Wet-Sanding, Cutting & Buffing
    Last Post: 12-12-2020, 08:24 AM
  2. Looking for some advice on wax application / buffing cloths
    By johnnymordoc in forum Ask your detailing questions!
    Last Post: 12-05-2018, 09:41 AM
  3. Need advice on spot buffing pads for DA
    By jdoublehcubed in forum Auto Detailing 101
    Last Post: 04-05-2014, 10:25 PM
  4. Advice for machine buffing new exotic cars
    By Radarryan in forum Auto Detailing 101
    Last Post: 11-22-2012, 11:30 AM
  5. Need Advice Buffing Fresh Paint
    By HMFIC in forum Auto Detailing 101
    Last Post: 03-30-2009, 11:41 AM
