Dislikes:
Headlight swirls
I used the 3M headlight restore kit and have light swirls that show when the the lights are on. Is there any way to get rid them?
Thanks
Re: Headlight swirls
Originally Posted by
K58
Thanks
Just about any polishing compound will remove the swirls.
3m kit is a great kit... sometimes I used to get some light swirling afterwards so I would use some power finish and an orange 4" pad..
I did the same thing and i realized that there wasn't anyway to get rid of all the swirls without doing 1500/2000 wet sand then polish.
Thanks for the replies
I might try some 1500 /2000 sanding
The 3M kit works well but it removes any UV protection. What do you suggets after I get the swirls out?
K58
Thanks
I use my Griot's 3 inch Orbital on an Orange pad with 3M light compound does the trick all the time
K58
Here are some good threads about using the Spar Urethane Method and Opti-Coat for headlight sealant, I think its really a matter of choice currently I use the Spar Urethane Method
Headlight sealant: spar urethane vs. opti coat 2.0
Headlight Restoration-new UV sealant idea
Hope this helps good luck
Louie
By geoguy in forum Show N' Shine
By rob42 in forum Auto Detailing 101
Last Post: 02-24-2016, 01:00 AM
Last Post: 05-29-2014, 07:48 AM
By miker2012 in forum Ask your detailing questions!
Last Post: 09-10-2013, 10:13 PM
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
S
M
T
W
T
F
S
1 2 3 4
