Touch up paint sanding
I just applied touch up paint to several scratches on a vehicle. I plan to apply at least one more coat once this one is set. I plan to sand down the painted areas to blend. My question is, I plan to do the sanding and polish out sanding scratches before applying top coat to the scratched areas. Is that the right order to do it in and should I dry or wet sand? Thanks, Chad
Re: Touch up paint sanding
By top coat, do you mean clear coat? Touch up paint, level sand with 2000, clear coat, polish out. Oh, I would wet sand.
Yeah clearcoat... And thanks for the confirmation. Your advice matches my plan to a T!
"My question is, I plan to do the sanding and polish out sanding scratches before applying top coat to the scratched areas. Is that the right order to do it in and should I dry or wet sand? Thanks, Chad "
Chad you do not need to polish out the 2000 grit sanding marks before shooting a clear. As
a matter of fact the 2000 sanding marks will give the clear coat something to adhere to.
By EJ88 in forum 3-Day CAR Detailing Bootcamp Classes - Info & Dates
Last Post: 10-09-2018, 01:53 PM
By spence in forum Tricks, Tips and Techniques
Last Post: 10-09-2018, 12:39 PM
By bentz69 in forum Wet-Sanding, Cutting & Buffing
Last Post: 10-07-2015, 06:18 PM
By kevin_1981 in forum Auto Detailing 101
Last Post: 07-30-2014, 03:59 PM
By slapshot in forum Wet-Sanding, Cutting & Buffing
Last Post: 11-13-2012, 05:55 PM
