Water spots showing on WGDGPS and Fuzion.....
I recently detailed my SUV and did the following;
-wash with WG Auto bathe (two bucket system)
-Pinnicle Clay
-WG three step swirl remover (with an IPA wipedown in between)
-two layers of WGDGPS
-two layers of fuzion
*by the way the products worked great and the outcome exceeded my expectations!!!!
The other day I washed my car (again using WG auto bathe & two bucket system) and it was roughly 105 head index with around 80% humidity. I tried to keep the car as wet as possible prior to drying with a Cobra waffle weave and use some FK QD as I was drying.
After the wash in the right light noticed I have faint water spots that aren't leaving.
Any suggestions regarding the easiest way to get rid of them?
Re: Water spots showing on WGDGPS and Fuzion.....
wipe down again outside of direct heat. Likely the minerals in the water dried quickly due to environment and left the marks. I highly suggest investing in a canopy if your environment is always hot and in direct sunlight or perhaps the CrSpotless system.
Try what killr said. Make sure the paint is cooled down a bit first as well. If that doesn't work try vinegar/water mix. If you get to them soon enough it works. Saved me a time or two.
:dancebanana:
Sky's the Limit Car Care
Wash before the sun comes up or while the sun is setting (or get a canopy). Direct sunlight is brutal. Even with great care it is too easy to get water spotting with that kind of heat.
I'm in Houston, so I feel your pain, ha ha.
What type of product would be recommended for the wipe down? I tried the FK QD after noticing the spots and it didn't work or seem to make a difference.
I was shocked that the water spots ontop of the WG products still left spots, is that normal? I haven't used either product prior.
when water (rain, wash, etc) burns off rather quickly due to heat, it can leave behind traces of the minerals in the water. I would likely rewash at this point outside of direct sunlight. You can indeed wipe down with white vinegar but likely should reapply wax/sealant as it will remove some of it. Harsh yes, but sometimes necessary.
A QD should always be used as a drying aid in this situation. Before drying, the car should receive one final and thorough rinse, and then get dried off with a generous amount of QD and quality microfiber drying towels.
If the FK QD's cleaners aren't removing the water spots, perhaps you should try a QD with stronger cleaners. No clue how strong or weak FK QD is when it comes to cleaning.
Honestly though, I am surprised that your problem is with water spots on the paint...usually it's the glass that will get stuck-on water spots before the paint.
I suspect that it's possible the paint may have had these water spots for a long time and applying two coats of Fuzion have really highlighted them. I know my Subaru (since I got it) had some ingrained water spots on the hood and the roof, but I don't see them much until I am rocking Fuzion, then they are a bit more obvious because the wax is so shiny.
By PaulMys in forum Auto Detailing 101
Last Post: 08-04-2020, 09:33 PM
Last Post: 06-26-2020, 06:10 PM
By brettS4 in forum Wolfgang Car Care
Last Post: 01-16-2015, 08:41 AM
By runrun411 in forum Auto Detailing 101
Last Post: 09-02-2013, 10:18 PM
By IID in forum Auto Detailing 101
Last Post: 08-28-2011, 04:29 AM
