Cleaner wax without wax topping w/ collinite 476 ???
Looking forna cleaner wax that doesn't really have a wax in it since I am topping it with 476
Or does it not matter that the cleaner wax has carnuba in it ??
Also should I avoid hybrids and sealants when using 476?
Re: Cleaner wax without wax topping w/ collinite 476 ???
"cleaner wax that doesn't really have a wax in it"... That would be a paint cleaner or polish.
Originally Posted by
2black1s
Most say they have some wax in it. Was curious if I would affect topping it with 476
Like John said above, a cleaner without wax is a paint cleaner. (Usually chemical, but not always.)
A polish is an abrasive paint cleaner/corrector. (Removes swirls & light scratches).
If you would like, you could use any kind of "cleaner wax" and then do a panel wipe before the 476, but then why not use polish?
By hand which product would be you recommend , to remove old wax and some swirl correction .
Recently used poorboys polish w carnuba , paint still felt a but rough like still had contaminatlnts
Also have zymobil cleaner wax, tried thus last year don't remember the results.
PaulMys
Did you clay first?
No... which would remove more contaminants. Cleanser wax or plish
Just trying to save some time it's it's for a daily driver
Collinite makes a a cleaner wax, or also known as an AIO wax. I have used it many times, very nice wax with some bite to it if you choose to be more aggressive via pad or machine speed. In the past, prior to Collinite bringing out their AIO, I used Poorboys Polish with Sealant. Duragloss 501, 101 and 105 also make a great base for either 845, 476 or 915. Prior to that, any of the Megiuars, or Mothers cleaner waxes also make a good base for the Collinite finishing waxes. No worries with any of them. Don't worry about if it has actual wax or not.
Don't the collinite cleanses say don't use on dark colors and or clear coat ??
wantboost
Not the new Collinite AIO, it is a newer product, two or three years ago it was brought out. Look into Collinite 325. It is 100% clear coat safe, won't stain trim (didn't for me). Very, very nice AIO.
