Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Sep 2021
    How many pads for a motorcoach?
    Hi!
    This is my 2nd question I just signed on the form so bear with me. I've been watching some of your videos Mike and I can say they are truly informative.
    Anyhow I'm planning to detail my vehicles and my motorcoach. And after watching your videos I just realized....I don't think I have enough pads especially for the motorcoach and possibly our SUV!
    The bus is 42 by 13' tall and 102" wide...with the slides out it s nearly 13'. This vehicle has been well taken care of by the original owners and lived in a climate controlled garage. It primarily saw most of its life with Turtle Wax car wash and carnuba's mother's wax. I see slight swirls and the paint.
    I have attached the photo of the coach in question
    Sent from my SM-G998U using Tapatalk
  2. Likes chilly liked this post
  3. #2
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,761
    Re: How many pads for a motorcoach?
    Quote Originally Posted by jcdata View Post
    Hi!
    I have been in the same situation and the first question is have you done a test spot or several test spots and know just what pad and product you will be using
    I kept my coach up and did a yearly once around with an AIO and then waxed as needed
    I used 6 pads and worked until those pads were all gunked up and stopped for the day, washed them, and then kept that up for a few days until I was done
    Between the labor of moving ladders around and extension cords tugging on me that was all I could handle
    But I’m also old and retired and had not much else to do
    Try a test spot and go from there
    What polisher and pads do you currently have, what products are you used to using, etc
    The more info we get the better
  4. Likes jcdata liked this post
  5. #3
    SELF BANNED
    Jun 2019
    1,076
    Thats a crazy detail man! I would prefer at least 20 medium pads for something like that - rupes yellow foam or wool comes to mind, they have a bigger face, the foam, so it will be more efficient then some pads - if you plan to just spend one day at it. But honestly it would take me a solid week to do something like that. And i really couldn't see me not using a waterless wash to prep the panels before polishing, after one good bucket wash on the whole unit. I'm a big fan of mckee's N914. Wolfgang makes a straight waterless too i think.
    Good luck!
  6. Likes chilly, jcdata liked this post
  7. #4
    May 2006
    Alaska
    1,761
    Quote Originally Posted by noorth View Post
    Good luck!
    What I should have said is the FIRST thing the OP needs to do, even before a test spot, is to decide on his expectations
    My first coach was only 32’ long and I quickly learned that swirls I would never allow on my car were perfectly fine on a coach
    Actually it’s easier than it looks in one respect
    It’s 90% flat surfaces and with a 6-7” pad you just start doing squares
    No dips or valleys or swoopy fenders and stuff
    But it’s also 99% vertical so you are supporting the weight of the machine and cord 100% of the time except for doing the roof
    It’s a job, that’s for sure
  8. Likes noorth liked this post
  9. #5
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Quote Originally Posted by chilly View Post
    You didn't bring that land yacht to Molokai?
  10. Likes chilly liked this post
  11. #6
    May 2006
    Alaska
    1,761
    Nope, I’d get to the end of the highways and have to leave it
    Nowhere big enough to turn it around
    Plus filling a 150 gallon tank at the prices here would bankrupt me
  12. Thanks noorth thanked for this post
    Likes Rsurfer liked this post
  13. #7
    May 2006
    Alaska
    1,761
    Good luck!
    I actually did exactly what you are suggesting
    Initial bucket wash and then when I was polishing I would clean top to bottom using ONR and wash a section about 4-5 feet wide by 2-3 feet and then do 2 polishing sections with 3D Speed and work my way down repeating the ONR for a section and Polish
    When I got to the bottom I’d go back up and wax/sealant my way down
    That was a day for me
  14. Likes PaulMys, noorth liked this post
  15. #8
    SELF BANNED
    Jun 2019
    1,076
    I'm curious, why don't you use periods? I picked up on it a few times now
  16. Likes chilly liked this post
  17. #9
    SELF BANNED
    Jun 2019
    1,076
    Must of been a lot of work.
    Personally i would of used 3D One probably if i was going to go over the surface with an LSP after using an AIO. Any medium polish.
  18. Likes chilly liked this post
  19. #10
    May 2006
    Alaska
    1,761
    Well, the post you quoted contained one long sentence and subsequent sentences were broken out as separate one sentence paragraphs
    It’s a habit left over from my years with the court system and the way they taught us to communicate with judges
    Each separate thought or topic is broken out as a self standing sentence
    Where it came from I can’t say but I did it long enough that it has stuck with me
  20. Likes noorth, jcdata liked this post
  1. Motorcoach topper
    By jcdata in forum Ask your detailing questions!
    Last Post: 09-08-2021, 06:53 PM
  2. Replies: 4
  3. Lake country hydro tech flat pads. Pads are ripping on my makita
    By Ncs0816 in forum Wool & Foam Buffing Pads
    Last Post: 10-04-2013, 08:38 PM
  4. CCS Smart Pads™ Dual Action 5.5 inch Foam Pads by Lake Country
    Last Post: 01-08-2008, 08:03 AM
  5. Replies: 5
    Last Post: 10-17-2006, 02:19 PM
