Results 1 to 7 of 7
    Super Member bob m's Avatar
    May 2009
    Glen Ridge, NJ
    294
    PPF and polishing?
    I have a 5 month old car with PPF on the whole front. Car has been hand washed and well cared for, but I'm going to be applying a coating, so I will be doing all the proper prep work - wash, Iron-X, clay (lightly), wash, wipe down and coat. I'll be using a fine polish, not a compound. I have used a polish on the PPF on prior cars, but giving it more thought, are there any down sides to polishing PPF?
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    Re: PPF and polishing?
    You are removing a small amount of materials each time you polish. More so than paint... heat is not your friend when it comes to polishing. Most reputable brands of PPF have some type of UV blocker unlike the PPF in the market years ago which would yellow as it age. There are PPF specific coatings in the market these days designed to address this.
  3. Thanks bob m thanked for this post
  4. #3
    May 2009
    Glen Ridge, NJ
    294
    Quote Originally Posted by psnt1ol View Post
    Thanks. So, best not to polish that PPF (XPEL ULTIMATE)?
  5. #4
    Mar 2017
    Southeastern PA
    2,480
    If the PPF is not scratched/marred, I would avoid polishing it to not remove the factory UV protection. If you need to polish, I'd try something like Gyeon PPF Renew which is made for this and probably not aggressive enough to damage the Xpel Ultimate you got. Might be wise to ask your installer for his recommendation.
    Bruno Soares
  6. Thanks bob m thanked for this post
  7. #5
    Aug 2012
    San Francisco
    892
    Quote Originally Posted by bob m View Post
    only if you have to. If it doesnt need it then dont do it. I used Renew to freshen up and to remove minor swirls on PPF with no ill effects but then I also had used a fine polish with a black pad in the past with pretty good success.
  8. #6
    I agree with everything already posted.
    I will say I've polished a lot of clear bras in my life and as long as you're using great abrasive technology and a soft foam pad you should be okay.
    I've never had a problem - knock on plastic.
  9. #7
    May 2009
    Glen Ridge, NJ
    294
    Thanks All. I have not checked it under lights, but I was considering it as much for gloss enhancement as much as anything.
  10. Likes oneheadlite liked this post
  1. Replies: 98
    Last Post: 06-26-2019, 06:14 AM
  2. Replies: 10
    Last Post: 08-01-2017, 08:00 PM
  3. Replies: 8
    Last Post: 04-24-2017, 02:59 PM
  4. Paint Polishing vs Metal Polishing
    By Crispy in forum How to Articles
    Last Post: 03-13-2015, 03:43 PM
  5. Is Polishing Compound Directly Related With Polishing Pads
    By Justin in forum Auto Detailing 101
    Last Post: 07-19-2008, 07:30 AM
