Originally Posted by
2black1s
My question, assuming you are using appropriate pads and polishes (or AIOs), for your final finishing, is how much pressure are you applying with the DA and are you lightening up on the pressure of your final few passes?
Anytime I have had a problem like you are describing I've been able to correct, or at least improve, the condition by...
1) Lightening up on the pressure for the final passes (equal to or even less than the weight of the machine, max)
2) Experimenting with machine speed
3) Increasing the amount of product used so the polishing is executed in a "wetter" state and shortening the polishing cycle (SMAT only)
4) As a last resort, doing the final finishing with a light hand polishing
