Re: HELP! Can't finish down without micro-marring on 2015 Ram 2500
One possibility, The white pad is too soft. I have found on some soft paints, I need to use a Blueberry pad(Reflection Artist blue coarse) and essence to finish out. I think a stiff pad and a finer polish will make your black paint dreams come true
Also, a shorter throw machine may help too
TMQ liked this post
Agree with Billy...
Sometimes stiff polishing pad with a fine polish helps.
I got pissed at one time trying to get soft paint corrected and grabbed the Griots 6" polisher---Bam, issue solved. Discovered this by accident!
Griots 6" Da with 8mm throw on the soft paint was actully more effective than the Rupes 15" throw!
It may sound counterintuitive --- Sometimes soft paint may respond better to a more abrasive polish with a stiffer pad on a short throw polisher.
This just might do the trick....
Tom
Mr Tommy's
Wash, Buff, Wax
Website: mrtommyshine.com
Thank you all for the advice. I’m going to get the G9 and give that a try also.
TMQ liked this post
Let us know how it went...
Tom
Mr Tommy's
Wash, Buff, Wax
Originally Posted by
2black1s
What I don't understand is why does the 105 side looks like it finished out better than the 105/205 side?
Regardless of the paint's hardness/softness something doesn't seem right. The 205 should always finish out nicer than the 105.
M205 is not the polish I would choose to finish out on soft paints. That is its Achilles heel. M210 is better but even that at times struggles on soft paints. Softer paints tend to like a stiffer pad.
To the OP I would look into a different polish that does a better job on soft paints.
TMQ liked this post
BlackRam15
I’m not 100% sure, but I’m pretty certain that the truck was not repainted. I will thoroughly read through the write-ups.
BlackRam15
PM sent with shipping info. Thank you!!
I'm off today, but will process tomorrow.
Also - if you have an order for pads already being shipped - get me the order number via PM
Been there done this!
First I suggest ditching the Meguiar polishes(205 and ultimate polish) They have been known to not finish well on some paints.
Second I would suggest just a 8mm free spinning DA.
After those it becomes a bit of trial and error.. I would suggest the following few polishes or the BF One Step Mike is sending you
Pinnacle Advanced Finishing Polish
Menzerna Polish PO85RD, Mernzerna 85rd, Menzerna finish po85rd, Menzerna Super Finish Plus
Above polishes and trying a few polishing to finishing pads should get you on track.
TMQ liked this post
No need to buy another machine...? That shouldn't be necessary.
