FINISHED THE GYEON PURE FRIDAY
finished the gyeon pure friday looks fabulous, will be getting some pics up soon, very easy application process. now what will be the best booster product to use and also a good quick detailer to use ?
Re: FINISHED THE GYEON PURE FRIDAY
Looking forward to the pictures.
As for a "detailer" - I'd keep it in the family and use the Cure
GYEON Q2M Cure - 400 ml
thats what i was leaning towards also or the wet coat , could the wet coat be used as a quick detailer
How do you intent to use the QD product? I see Cure as more of a topper/booster than a QD product you'd use to do things like remove bird droppings or finger prints/smudges.
One trick I found with Cure is to dilute it 50/50 with water. It is easier to apply and less prone to streaking when diluted.
You can stay within the family. Gyeon offers both a QD and booster.
GYEON Quick Detailer
i like using a quik detailer for removing smudges etc, i like the idea of diluting the cure 50/50 and using that as a detailer, sounds like that would work good what are your guys thoughts on that ?
I'd use Gyeon's QD for what you describe above. From my experience with Cure, I don't see it working well in that role, it is more of a booster.
I'll also say I've never used Gyeon's QD. I think it's a fairly new product, but would probably be your best bet if you stay "in the family" compared to other products in the Gyeon line. I used CarPro's Ech2O as a QD on Gyeon's CanCoat and it worked great.
