Re: Using wool pad for first time
Originally Posted by Akf75
Thanks Mike, will do. Can I try it with the DA polisher? Or will it not do the work?
There are two versions of Sonax Perfect Finish.
One geared toward rotary and the other towards da.
This is the one you want for da.
SONAX EX 04-06 1000 ml.
Ripping through your mind like a hurricane full of novocaine
Both are 04-06 and both work well with a DA, IME.
Are you sure it needs wool? I would at least do a test spot with either of the recommended Sonax polishes and determine what pad would work. I will also say the Rupes yellow foam is great and works well with Sonax Perfect Finish. It also finished out so good with Meguiar's D300. It is all paint dependent. Let us know how it goes.
Good point. No I am not. I will go with the compounds and an agressive foam pad first on a test area. Then go from there, thanks everyone.
While SONAX purposefully formulated Perfect Finish for use with a rotary polisher - I've used it with orbitals and no problems.
I think we're talking about two different products in this thread,
There's a product called EX 04-06
SONAX EX 04-06 250 ml.
Yes, that's it's name. --> EX 04-06
Then there is a separate product and while it has the same cut and finish it actually has the name,
Perfect Finish
Sonax Perfect Finish 4/6
Both are great products. I show them in my classes.
By mwoywod in forum Ask your detailing questions!
Last Post: 11-02-2017, 08:31 PM
By sansa in forum Auto Detailing 101
Last Post: 02-24-2016, 12:48 PM
By Tacket in forum Product Reviews
Last Post: 07-14-2014, 11:22 PM
Last Post: 08-29-2012, 10:40 PM
Last Post: 11-09-2007, 10:20 PM
25 | 26 | 27 | 28 | 29 |
