Wool pad for headlights
Seen wolfgang used a wool pad on headlights. My headlights are needing some tlc themselves I do have the wolfgang headlight kit but seeing if a wool pad with it will give it a better look and I guess easier to come clean if so is there a certain type of wool pad I should use..thanks in advance
Re: Wool pad for headlights
I'd think the LC foamed wool pad might be a good choice. It's less aggressive than twisted wool pads.
Originally Posted by
Blacklightn25
thanks in advance
Yes there is a certain type you should use. The type depends on the tool or polisher you own.
What do you have and use?
I have portable cable but last time I did try it with a drill
