Re: HELP PLEASE! Film all over after polishing
Originally Posted by
PaulMys
Which machine broke?
G15
All you need to do is TROUBLESHOOT the paint problem. I should have written an article on how to troubleshoot paint problems 20 years ago. I'll try to get to it ASAP.
First let me got to Skynet and see if I can find the definition and directions for how to troubleshoot that I've already written in the past so I don't have to re-type content I've already created.
Took testing a few key words but here's what I typed into Skynet
troubleshooting troubleshoot paint problems mike phillips autogeekonline.net
For everyone that reads this into the future - if you use the right key words and add my first and last name you can usually find an article or two, or an in-depth reply for the topic you're dealing with.
Here's post #7 and this is what you want to do.
https://www.autogeekonline.net/forum...ml#post1477036
Paint Defect Troubleshooting
I place a strip of painter's tape across the middle of the defect or defects and then just buff on one side of the tape. Wipe off the residue and inspect to see if the side you buffed is getting better or no change.
Paint Improves
If it's getting better then remove the tape and buff the entire area. You may have to use a more aggressive tool, pad or product.
No Change
If no change then this tells me whatever the defect or defects are they are either,
1: Throughout the matrix of paint. Matrix means the entire film build.
2: Under the clearcoat
And neither of the two things above can be fixed.
But yeah, from the pictures it looks like there's a film on the paint but I doubt it's the wax. Try placing a strip of painter's tape over a section and then only buff on one side of the tape line. Do 8 solid section passes and then immediately wipe-off.
AND - maybe try a quality compound instead of a cleaner/wax.
Mike, once again thank you so much for your help. The amount of frustration had me researching all night and everything I came up with was “sticky” paint on Subarus plus the condition of the paint.
My new test as we speak is a LC black pad with 1-2 sprays of detailer and it’s removing the residue.
This may make me turn down a Subaru in future lol.
Ty!!
detailjja
Interesting fix. Also just about 100% opposite of what I would do and what I recommended. BUT - if it works - that's all that matters.
detailjja
Ty!!
Maybe look for a one-owner, well-kept, perfectly preserved and maintained Subura BRAT.
The best Subuaru ever!
It’s crazy how each car differs from one to another.
Thanks again for all you do.
Did a black Subi last week and came out perfect. M205 LC white and orange pads with long throw and pc da. Finished with Fk.
