» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Sep 2020
    Re: P21s/Maguiar’s Ultimate Wax
    First - since this is your first post to the forum,
    Welcome to AutogeekOnline!
    The Meguiar's Ultimate line is very good.
    My guess is without ever seeing the car, after 9+ years - well my guess is the car will fail the Baggie Test. I RARELY come across a car that passes the Baggie Test. And the two most common places cars get overspray paint are body shops, (where they spray paint), and a Car Guy's Garage - because car guys tend to use Rattle Cans and never cover their car. Just saying...
    The Baggie Test as seen on Competition Ready TV with AJ and Mike Phillips
    Nothing against P21S but last I checked it's a traditional Carnauba Wax. Meguiar's Ultimate Wax on the other hand is going to be a "blended wax". This means the chemist will include a blend of ingredients to bring out all the best appearances features of urethane paint plus add protection.
    That said, if you did the proper prep work to a white car and then used both products - you probably couldn't tell the difference as that is the downside of white paint. You do not get the deep dark reflections like you get with dark colors. Normally what I aim for is to maximize gloss and the way you maximize gloss is by having a smooth surface. A smooth surface starts with smooth paint and if paint fails the baggie test then it will not be as glossy as possible.
    Thanks Mike for the detailed response. Let me ask you this. Assuming the car does need to be clayed, would it be beneficial to follow it up with the P21 paint cleaner before waxing? Thought is the cleaner would polish out any “maring” from the clay.
    Aug 2020
    193
    I used P21S years ago and while it looked good the durability was poor. Chances are that if you are in a hot climate it will break down even in a garage.
  3. #13
    Senior Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    I would suggest trying Meguiar's Ultimate Paste Wax and skip the P21. The P21 as a carnauba wax will turn acidic overtime. Ultimate Paste Wax is probably the only non-SiO2 based protection I still use.
    Meguiar's ULW and UPW seem to have different results, I remember UPW having a very wet but very bright shine.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  4. #14
    Jun 2009
    Stuart, Florida
    48,319
    Quote Originally Posted by Javaman12 View Post
    Thought is the cleaner would polish out any “marring” from the clay.
    Kind of... the P21S Paint Cleaner is non-abraive - thus the name "paint cleaner" not "paint polish", thus it will not remove marring. It may mask or fill marring just like the wax will but not actually remove it.
    And thus is the quandary for so many people,
    To clay or not to clay?
    My own personal rule is if I clay a car I have ALREADY factored in doing at least ONE machine polishing step to remove any marring or potential marring.
    Here's a great example. A BRAND NEW SPANKING car with no real visible swirls or scratches except in a few places and the Piano Plastic but it needed to be clayed.
    Review: IGL Poly Ceramic Coating - 2020 Porsche 911 Carrera S
    Failed the Baggie Test
    Clay is not shown - forgot to grab it for the picture but I did in fact clay using the Pinnacle Ultra Fine Grade Detailing Clay
    Tools - Pads - Products
    I know it's easy to think to "install" a ceramic paint coating on your car all you have to do is order the coating, as in order the tiny glass bottle of product. But that's a false reality. In the real-world, you're going to need a polisher, pads, products and lots of clean, un-contaminated microfiber towels to do the job right.
    Here's a few pictures showing what I used to install a ceramic coating to a brand new Porsche.
    And as expected and was one of the goals - extreme GLOSS
    So if a person does NOT own a polisher - do you clay?
    Because your Corvette is white, you will never see any marring. Plus - if you use an ultra fine grade or fine grade and LOTS of lube - you're safe enough to go over it.
    Remember - I have to type and teach for the most EXTREME OCD type people.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
  5. Likes acuRAS82 liked this post
  6. #15
    Senior Member acuRAS82's Avatar
    May 2017
    Pittsburgh PA
    2,570
    “Remember - I have to type and teach for the most EXTREME OCD type people.”
    Well put, Mike.
  7. #16
    Senior Member Me Time's Avatar
    Apr 2016
    Louisville The Derby City
    148
    I have done both on the older white Escape we have as far as claying and following with a polish and with out. It all matters the time I have. But these are my own vehicles.
    If I was working on someone else's it would get polished after, unless the owner is fine with the way it looks. But they would have to understand that it is what it is if they did not want to put out for it.
  8. #17
    Apr 2016
    148
    Quote Originally Posted by WillSports3 View Post
    I have both and remember there being a difference, but did not remember what. It has been a while since I used either one.
  1. Help and advice needed for Maguiar's 105 and 205
    By WilliamSit in forum Auto Detailing 101
    Last Post: 09-05-2016, 08:06 PM
  2. Just received two gallons of Maguiar's Last Touch
    By HateSwirls in forum Product Reviews
    Last Post: 12-03-2014, 08:36 PM
  3. Wash > Clay > Ultimat Ultimate Compond > Ultimate Polish > Ultimate wax?
    By SArao in forum Ask Mike Phillips your detailing questions!
    Last Post: 10-01-2014, 11:25 PM
  4. Replies: 5
    Last Post: 09-13-2013, 04:18 AM
  5. Attended a Maguiar's factory demo today
    By Spiney in forum Off-Topic
    Last Post: 05-07-2012, 01:04 AM
Members who have read this thread: 49
» September 2020
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 123
