Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Hand polishing
    Jun 2020
    Re: Hand polishing
    I'm sure I have an article on this somewhere but can't think of the title?
    Here's the deal, (I type this out all the time every year),
    It takes MORE skill to work on clearcoat paint by hand than it does by machine. And in this context I mean an orbital polisher - not a rotary buffer.
    I could fix this scoured mess by hand. I make a video next week and how you how to do it.
    It will be faster and easier and also safer to somehow get an orbital polisher, a foam buffing pad and some Meguiar's Ultimate Compound - available just about anywhere and buff the area.
    Word.
    How and where do I find this video? And am I right saying these are scratches left by a more agressive compound?
    I am just hoping it needs some finishing polish Hand polishing
    Re: Hand polishing
    Quote Originally Posted by Edvinac View Post
    I'll need to create the video and I won't be able to get to it until next week.
    And "yes" there really are no other videos you can find that show the correct way to hand apply a compound to remove swirls and scratches out of clearcoat paint.
    Probably what I'll do is machine sand a black demo hood with #2000 grit sand paper and then show how to remove the sanding marks by hand. Apologies I cannot get to it today or tomorrow - just have other things to get done.
    If you want to try get some ScratchX or Ultimate Polish (kind of the same thing, they are LIGHT POLISHES). You're also going to need some Ultimate Compound. Also get a quality microfiber applicator pad and also a foam applicator pad. You can find these things at most auto parts stores.
    Then work the area with the Ultimate Compound and the microfiber pad and some FIRM downward pressure. I would use a straight line motion for the initial applications simply because it's easier on you to rub hard in back and forth motions versus circle motion.
    After work the area with the the compound and the microfiber applicator pad and you're happy with how the paint looks. Then switch over to either ScratchX or Ultimate Polish and now use the foam applicator and repeat. I'd probably work the are pretty hard for the first application to improve the results of the compounding and then start reducing your hand pressure and polish more lightly.
    Polishing paint is an art form - not a grinding process -Mike Phillips
    The microfiber has more BITE than foam - that's why you start with it. The foam is less agressive than the microfiber that's why you finish with it.
    Then slap some wax on the trunk lid, stick a fork in it and call it done. Moving forward, be a little more cautious with what products you choose to rub over scratch sensitive clear coats.l
    If you tackle this - let us know how it goes and good luck.
    It takes a LOT more skill to work on car paint by hand than it does with a modern orbital polisher.
  3. Likes Edvinac liked this post
  4. #13
    Jun 2020
    Re: Hand polishing
    I am really gratefull to have people like you.
    You don’t hesitate to explain everything. I deeply respect your knowledge sharing skills.
    From my understanding ultimate polish should fix this? No need for compounding? (i am assuming I’m already pass this stage after the marks MY polish left).
    Also I am guessing products you’re talking about are meguiars Some questions about the products themself:
    Does ultimate compound and ultimate polish have any silicones in them to hide scratches?
    Diffrences between swirlx and ultimate polish?
  5. #14
    Re: Hand polishing
    Maybe UP would work. You can try. If it's not working fast enough to level the surface and thus remove the scouring, then you could try UC. UC = Ultimate Compound.
    The thing is - UC and UP both use SMAT - Super Micro Abrasive Technology - they will both feel like Jergans Hand Lotion. Very safe. The UC would work faster with lest talent.
    Yes. I know a little bit about the M-Line. The red car on UC was from one of my Thursday Night classes when I worked for Meguiar's in Irvine, the black car was a BMW I did a half-n-half for the 2002 Bimmerfest.
    Meguiar's Ultimate Compound History
    Meguiar's Ultimate Compound and SwirlX
    Don't know but don't think so. Wouldn't be a concern to me. If properly worked they would remove the defects not mask them.
    Probably the main change was switching to the "ultimate" branding while dropping the "X" branding. Swirlx and I think ColorX are both gone now.
    If you're not in a hurry - I'll make a video next week showing how to do this - heck maybe Yancy and I can make this our Thursday LIVE Detailing Class.
  6. #15
    Jun 2020
    Re: Hand polishing
    Well to update I’ve ordered UC, UP, microf applicator, soft foam applicator and clay. Just don’t have them yet, I will update when I tackle the job.
    Found some videos on youtube guiding how to use these products and always mentioning its really good in hand polishing compared to traditional pastes. We will see Hand polishing
    Thanks for the answers, where can I catch you live or watch the recording?
  7. #16
    Re: Hand polishing
    Did my best to share how to work by hand using a keyboard.
    I know it's hard to know where all the vast amounts of information are located on this forum or on any of our other social media touch points but normally when I have anything coming up it's on the bottom of the forum homepage
    Autogeekonline Auto Detailing Forum
    Or you'll find an update on my FB page
    Mike Phillips - Home | Facebook
  8. #17
    Jun 2020
    Re: Hand polishing
    Followed on facebook Hand polishing
  9. #18
    Jun 2020
    Re: Hand polishing
    UPDATE
    So I used Clay+Ultimate compound+Ultimate polish+ADBL synthetic wax.
    The products did exactly what I wanted them to do. Ofcourse there are some deep scratches left, but that’s to be expected.
    Thanks for consulting, have a nice day!
  10. Likes PaulMys, Coatingsarecrack liked this post
  11. #19
    Super Member Me Time's Avatar
    Apr 2016
    Louisville The Derby City
    219
    Re: Hand polishing
    Nice job.
  12. #20
    Re: Hand polishing
    Here's the LIVE Detailing Class video we made where I show how to correctly work a COMPOUND by hand to remove paint and thus level the paint surface.
    LIVE Detailing Class - How to compound and polish by HAND
  1. Hand Polishing
    By spielwurfel in forum Auto Detailing 101
    Last Post: 09-23-2016, 03:42 AM
  2. Can polishing be done by hand?
    By Jrdriver in forum Auto Detailing 101
    Last Post: 12-23-2015, 07:43 PM
  3. hand polishing
    By charlietuna in forum Ask your detailing questions!
    Last Post: 08-10-2013, 01:01 PM
  4. hand polishing car
    By GT500 in forum Auto Detailing 101
    Last Post: 06-13-2012, 01:03 PM
  5. Polishing by Hand
    By OTPAS in forum Auto Detailing 101
    Last Post: 02-28-2007, 08:12 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
