Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Mar 2016
    Rochester NY
    Re: When coarse isn't enough
    really dumb question, how do you know if a particular polisher is gear driven or free spinning? the Rupes in the pic above looks very similar to my LHR21. I assume the product details will tell me the spinning mechanism?
    Maybe I should purchase a gear driven polisher for trim, something that takes a 2 or 3 inch pad? Any recommendations?
    Pic issue fixed (obviously), I assume the issue was the file size, I was just over 5MBs originally, resizing in Paint (windows 10) worked.
    Take your finger and try to spin the backing plate.
    IF the tool, any brand, is a free spinning polisher you can spin the backing plate with your finger - easily.
    If the tool is gear-driven orbital - you'll have to physically GRAB the backing plate and force it to rotate/oscillate.
    Good question - I show this in all my car and boat detailing classes BECAUSE it drives home a simple point that most people can then wrap their brains around.
    I'll show that in the live class today.
  3. #13
    Quote Originally Posted by TTQ B4U View Post
    ^^ is the above going to be recorded and posted on YouTube or anything?
    Yes.
    All our live classes are hosted on the AG YouTube channel and I add them to this growing list here on the forum.
    Complete List of Live Broadcast Videos on YouTube - Yancy Martinez & Mike Phillips
  4. Thanks TTQ B4U thanked for this post
  5. #14
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    You may also want to look into some fiber pads to do your cutting with. Check out LC purple wool and the Rupes wool. Will help with pad rotation and cut more than the blue Rupes foam pad.
  6. Thanks mrasmussen thanked for this post
  7. #15
    Mar 2016
    Rochester NY
    I watched the video, really good info. I should have gotten a gear driven polisher. Also, instead of using the 4 steps from Rupes I would rather have done 1-2 steps for a daily driver.
    I see Flex has a trim polisher with a battery (sold out it appears). Is that a gear driven tool?
  8. #16
    Quote Originally Posted by mrasmussen View Post
    And just to note - RUPES also has a gear-driven polisher called the Mille
    Do you mean the FLEX PXE 80 ? I've never seen nor heard of it called a Trim Polisher.
    Pictures: New FLEX PXE 80 10.8-EC by Mike Phillips
    If you mean the PXE - the answer is a 2 part answer.
    Yes - The PXE is gear-driven when you have the rotary drive unit installed.
    No - The PXE is free spinning random orb it when you have either the 3mm or the 12mm drive units installed.
    At this time - there are no small or micro-tools that are gear-driven orbital.
    Or do you mean one of the other compact FLEX tools?
    FLEX XFE 7-12 3" Mini Polisher
    FLEX PE8 Kompakt Rotary Polisher, motorcycle polisher
    And never heard these referred to as trim polishers but "yes" all three above would be functional for polishing trim or thin panels.
  1. To use both fine&coarse polish products or not ?
    By octavia83 in forum Auto Detailing 101
    Last Post: 08-27-2014, 11:33 PM
  2. Coarse Green or Orange Pad, which is more aggressive?
    By JAF06SE in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 09-11-2012, 08:12 PM
  3. Single stage crash coarse!
    By Kody in forum Ask your detailing questions!
    Last Post: 09-03-2012, 09:50 AM
  4. Orange pad, Coarse green
    By dsjohn in forum Ask your detailing questions!
    Last Post: 08-08-2012, 01:05 AM
  5. Why no Coarse Green 5.5" :C pad?
    By stevehecht in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 09-15-2009, 07:57 AM
