» Detailing Classes
Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
  1. #41
    Senior Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,202
    Re: What Happened To My Ceramic Coating?
    Chemical Guys Speedshine Detailer. Has basically the same level of protection, and hides light swirls. Also adds gloss. Also can be used in direct sunlight without any finicky application processes.
    Turtle Wax Jet Black Spray Wax was able to do that as well, not sure if it still is in production.
    Any kind of cheap detail spray that contains Silicone will do basically the exact same thing.
    Reloads adds gloss, and then kills the coating underneath. Not sure if that makes it worth applying at all.
    At the same time, I haven't seen protection from it yet. Adds gloss and visually decent water beading. However in practice, the water does not bead off very well. Lower contact angle on the product.
    I don't know if I would call it a spray sealant. Sealant seems like too much of a stretch for what it does and doesn't do.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  2. #42
    Senior Member Eldorado2k's Avatar
    Nov 2015
    Los Angeles, California
    11,124
    Well it certainly isn’t a quick detailer like alot of people go around calling it.
  3. #43
    Jun 2016
    Toronto, ON
    1,202
    No, it's definitely not a quick detailer. Mind you, it's not just Reload. Reload, Cure, etc, a lot of those products I find give great water beading, and adds some gloss but that's usually about it.
  4. #44
    Nov 2015
    11,124
    Quote Originally Posted by WillSports3 View Post
    In your opinion what specific thing does Reload fail to do that prevents it from being a good spray sealant?
  5. #45
    Jun 2016
    Toronto, ON
    1,202
    The contamination build up from Reload. For whatever reason, a month after having reload on with consistent washes, the paint already feels like sandpaper again. I don't get that with the other protection that I've used. I use Iron X on Reload, and it degrades the Reload on the paint and I still feel like I need to clay after. Not something I encounter necesarily with a lot of other products.
    Now the newest version may have changed this, but all the versions I've used, it required a finicky application. I used to put two spritz or so per panel on a damp microfiber towel to avoid streaking. I've applied it in all temperatures and found it streaked like crazy. I was using decent quality microfiber towels to application and removal. Whether that method affected the durability, I don't know. But that's also the only way I've found it to be usable.
  6. Likes Eldorado2k liked this post
  7. #46
    Nov 2015
    11,124
    I was hoping you’d say that. We think alike.
    That’s my #1 priority when it comes to lsp.
  8. Thanks WillSports3 thanked for this post
  9. #47
    Jun 2016
    Toronto, ON
    1,202
    Don't get me wrong, I use coatings for myself but I use fall out remover and it's back to being fine after a good wash. That I can accept but with Reload, it feels like the next step is to clay and re-polish lol
  1. Blackfire Pro Ceramic or Mckee's New Ceramic coating
    By karwashboy in forum Auto Detailing 101
    Last Post: 04-16-2020, 09:39 AM
  2. Wheel Ceramic Coating Vs Regular Ceramic Coating
    Last Post: 03-28-2019, 02:09 PM
  3. Replies: 15
    Last Post: 02-02-2019, 12:17 AM
  4. Replies: 12
    Last Post: 02-04-2016, 07:15 PM
  5. WG Uber Ceramic coating or New Gloss coat ceramic forumla
    By Mike@ShineStruck in forum Auto Detailing 101
    Last Post: 12-19-2015, 01:42 PM
Members who have read this thread: 123
» July 2020
