» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Jun 2009
    Stuart, Florida
    44,014
    Re: Ceramiclear clearcoat
    Quote Originally Posted by prin View Post
    Thanks for the input Mike!
    I used Sonax Cutmax along with a Meguiars red pad. I even used a lot of pressure at some points and it was like I wasnt even cutting. I tried M110 as well with the same results.
    When it comes to difficult to remove swirls, it can be a number of factors.
    1. Paint is very hard.
    2. Swirls and scratches are deep.
    3. Combination of 1 and 2
    4. Wrong pad
    5. Weak tool
    6. Technique needs tweak
    Read through this,
    DA Polisher Trouble Shooting Guide
    Regardless, the thing about the Ceramiclear paint system is you're NOT supposed to compound it hard or you remove the portion that makes Ceramiclear Ceramiclear.
    Just a guess - but did you buy this car used? Or is it a customer car?
    Sounds like someone else has caused a problem that might not be fixable.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
    Senior Member prin's Avatar
    Oct 2008
    Huntsville, AL
    224
    4. Wrong pad
    5. Weak tool
    Read through this,
    I first started using little pressure like always. This did nothing, so I added pressure and I had the same results. The polisher that I’m using is a Rupes Mille. This is a customers car that was bought used.
  3. #13
    Senior Member Coach Steve's Avatar
    Jun 2013
    Chandler, AZ
    392
    I just did an ml500 C040 black 3 days ago. I almost turned it down due to the frustration and headache associated with Ceramiclear. This thing was trashed! You name, it had it. But, it was a friend of a friend that wanted to throw me all of his commercial business so I took the job.
    I don't know what Mike has been smoking but, Ceramiclear as a rule, is hard or at least the top 2-4 mils are. It's designed that way. Once the vehicle has been compounded the first time, the remaining paint is soft, like Honda soft. The person above who stated they only apply it to bumpers and kits is wrong The whole car has it.
    This vehicle had never been corrected so I had my work cut out for me. I used Menz HC400 with Uro-Fiber pads on my 15mm DA. I started with 3D 501 AAT which finjshes down better and leaves no haze, but it didn't cut as well so I switched to the Men's which required following up with FG4000 to remove the haze and dial it in. This was only for the horiz surfaces. The vert surfaces I was able to use the 3D which was a Time saver.
    The Uro-Fiber pads are some very powerful pads. They cut very well and the low nap and thinner profile allows them to be. blown out quite thoroughly which cuts down on having to change pads as often.
    Overall, it came out pretty well but it took about 8 hrs to correct. The customer was ecstatic which is really what counts at the end of the day.
    The part above about the Ceramiclear being very hard unless it's been corrected previously, is something to keep in mind when deciding to take a jkb or not. If it's ever been compounded, it's a completely different ball game and is very easy to correct.
    Look at the paint code. If it has the letter C in front of the numbers, it's Ceramicoat.
  4. #14
    Senior Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    3,907
    I have worked on many many MB and I honestly can not tell the difference between their regular clear and ceramic paints. Maybe I am just dumb but I doubt it. They are all nice to correct IMO. Hard enough that they don’t tend to haze yet not so hard that a quality compound struggles. I would agree with Mike’s assessment saying they are in the middle. But each individual paint can be different.
    I would look into other factors. Perhaps technique.... perhaps try a different tool than the Mille(or use the Mille specific polishes)...perhaps there is something on the paint that you need to remove via claying or chemical decontamination..... start at the basics!!
    Jim
  5. #15
    Jun 2013
    Chandler, AZ
    392
    Oh, it was clayed and prepped properly. Maybe you and Mike got lucky. I can only go by what I've experienced. Why would Menz go.to the effort of making a pkg specifically for Ceramiclear which includes FG400 to be used at the factory if it wasn't hard and needed a very aggressive compound to be able to cut sufficiently?
  6. #16
    Oct 2008
    Huntsville, AL
    224
    I think I got it!!!!
  7. Likes rlmccarty2000, kafas liked this post
  8. #17
    Jun 2013
    Chandler, AZ
    392
    What, no follow up?! What did you use to get it?
  9. Likes prin liked this post
  10. #18
    Oct 2008
    Huntsville, AL
    224
    Lol. Sorry Steve. I was so excited that something was working!!! I used the swirl remover by Wolfgang.
  11. #19
    Jun 2013
    Chandler, AZ
    392
    Ok, good to know. I wasn't sure if you got your hands on some obscure compound infused with ground unicorn horn or something.��
  1. Has anyone worked on a 2016 BMW X5? Ceramiclear or no?
    By emmjay in forum Auto Detailing 101
    Last Post: 10-05-2016, 06:00 PM
  2. Reccomended polish for hard clearcoat (and ceramiclear)
    By 11B250 in forum Ask Mike Phillips your detailing questions!
    Last Post: 06-20-2016, 07:45 AM
  3. Clearcoat Fracturing versus Clearcoat Failure
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 01-04-2016, 01:43 PM
  4. Ceramiclear swirls
    By jerber1 in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-14-2014, 06:16 AM
  5. Clearcoat Burn Through - How to tell? Missing Clearcoat Strike-through
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-12-2013, 06:15 AM
Members who have read this thread: 74
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
