» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Scratching or?
    Oct 2019
    Re: Scratching or?
    Tony,
    Thanks for your swift and extensive response. I will take your advise and start trying some things to see variations. I was really amazed to read your comments on brand new towels as I have seen some pro detailers pull out only new towels on expensive cars. As the most expensive car I treat (my own) deserves the best I was of the opinion new ones would be the way to go. Will pay more attention there.
    Andre.
  2. Likes SWETM liked this post
  3. #12
    Oct 2019
    Re: Scratching or?
    Quote Originally Posted by Jayfro View Post
    I had this happen to me a few months ago when I compounded and Polished an Audi S4 with Pinnacle, I went into panic mode thinking I marred the paint, but when I wiped in a different direction, mysteriously the marring/scratches "moved" in a different direction...WTH!!! As it tuned out, my MF towels were shedding fibers into the polish! I quickly changed towels and all was well in the world!!
    Jay
    Hi Jay,
    How did you notice fibers into yor polish. As you stated panic took over I guess it was not too obvious.
    Thanks for answering,
    Andre
  4. #13
    Apr 2019
    Houston, Texas
    288
    Re: Scratching or?
    Quote Originally Posted by Andre1961 View Post
    Hi Jay,
    Andre
    It was very apparent when I pulled the car outside into the sun and since it was around 1:00 the sun was high and shining directly onto the hood where I did the test spot. Inside the garage it was hardly noticeable.
  5. #14
    Oct 2019
    Re: Scratching or?
    Thanks Jay,
    Unfortunately we only have sun in June overhere.
    Will try to change some things over the coming weeks and revert back if I found the cause. Unfortunately I need to go on a business trip so can only try later.
    Regards,
    Andre
  6. #15
    Jul 2016
    3,243
    Re: Scratching or?
    Some products just don't wipe off clean I find. Use a different product and make sure you're staring with surgically clean paint, clean tools and compatible products.
    Microfiber is not supposed to be used straight out of the package unless it's pre washed which is rare.
  7. #16
    Senior Member Rsurfer's Avatar
    Jan 2007
    12,056
    Re: Scratching or?
    Thanks Jay,
    Will try to change some things over the coming weeks and revert back if I found the cause. Unfortunately I \need to go on a business trip so can only try later.
    Regards,
    Andre
    Where in the world are you, that you only have sun light during June?
  8. #17
    Senior Member Dan Tran's Avatar
    Sep 2015
    York, ME
    918
    Re: Scratching or?
    After watching the video:
    The first thing that came to mind is possibly the fact that polishing oils are still existing on the paint.
    Typically I wash my brand new towels also. But have also used fresh new ones no problem.
    But as someone had mentioned, some products don’t wipe off as clean. Possibly, at that time I would suggest a panel wipe. I am currently using Optimum Paint Prep. It has a nice glide to it. CARPRO Eraser is excellent too!
    High-End Paint Correction and Opti-Coat Ceramic Coatings * Portsmouth, NH
  9. #18
    Senior Member rangerbay's Avatar
    Jun 2017
    Enterprise, Al.
    256
    Re: Scratching or?
    I never use new towels without washing them first with a good microfiber wash like 3d towel clean.
    It may not make a difference, but I feel like they are softer and more absorbing
    Bill
  1. How am I scratching my car?
    By alexramsey in forum Ask Mike Phillips your detailing questions!
    Last Post: 12-12-2017, 04:51 PM
  2. Minor scratching with clay bar
    By buddiiee in forum Auto Detailing 101
    Last Post: 06-26-2014, 11:25 AM
  3. Scratching Microfiber
    By PremierAuto_NJ in forum Ask Mike Phillips your detailing questions!
    Last Post: 06-17-2014, 10:32 AM
  4. Avoid scratching when using a QD?
    Last Post: 01-14-2010, 08:32 AM
  5. Cobra MF scratching?
    By cannondalemr in forum Auto Detailing 101
    Last Post: 05-01-2008, 08:14 PM
Members who have read this thread: 48
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
