Results 1 to 4 of 4
    Jun 2019
    2015 GMC Truck with Pine Sap etched in clear coat and swirls
    I am looking to do my first paint correction on a 2015 Black GMC Sierra. It has pine sap all over the paint, glass, and plastic trim. I took the truck over to a buddy's body shop and he used 3M Rubbing Compound and a pad that seems to fix the paint. What products would you suggest I use such as a compound, polish/swirl remover and pads with my Flex 3401? I already have the LC force white pads and waiting on orange ones as well.
    Thx
    Super Member van185's Avatar
    Oct 2011
    Western NC
    502
    Re: 2015 GMC Truck with Pine Sap etched in clear coat and swirls
    Without seeing pictures it's hard to say what all might need to be done with the paint. Pine sap will etch through the clearcoat and often cannot be corrected with most details. In the past I have used Stoner Tarminator and a plastic razor blade to remove the pine sap. This will oftentimes also remove some of the clearcoat or the clearcoat may already be etched to the point of no return. After removing the pine sap you will need to clay the paint and then use a compound or polish to lighten the etching. A coat of wax will need to be applied after the polish or you could use a All-In-One Cleaner wax. The orange pad will remove more defects than the white pad. If you use a compound I would follow that with a polish and then a wax for protection. I'm sure others will have different advice but this has worked for me over the years.
    Jan 2014
    SoCal
    1,122
    I've never had etching from sap. I just take it off with isopropyl alcohol.
    Oct 2011
    Western NC
    502
    I have on several vehicles. For some reason Subarus seem to be the worst. Not sure why. We live in areas with lots of pine trees and every year I get several that Pine Sap has etched.
  1. Small Spot of Clear Coat Failure. Should I Still Ceramic Coat The Truck?
    By Jacob Harrod AUTOCLEAN in forum Auto Detailing 101
    Last Post: 10-03-2020, 08:03 PM
  2. Replies: 2
    Last Post: 04-17-2020, 12:58 PM
  3. Dry spot on clear coat newish truck?!?? Shady paint job ?
    By Cleanfreeek in forum Auto Detailing 101
    Last Post: 09-16-2016, 11:10 AM
  4. Etched clear coat. Help
    By Cvjeticanin in forum Ask your detailing questions!
    Last Post: 03-26-2015, 06:29 AM
  5. Help! Really bad swirls/no clear coat!?
    By JBs in forum Auto Detailing 101
    Last Post: 04-30-2007, 08:50 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
