Results 1 to 9 of 9
  1. #1
    Newbie Member
    Join Date
    Apr 2019
    Posts
    2
    Post Thanks / Like
    Applied 2x Optimum Gloss-Coat Paint, can Klasses AIO after?
    I had prep the car and applied 2 coats of Optimum Gloss V2.
    (First coat is on Monday, and 2nd coat is on Thursday)
    On Friday, my brother came and brought his klasses AIO and worked on his car. He suggested I should use the AIO on my car and then put on optimum Opti-Seal after.
    The question is, will the Klasses AIO polish out my ceramic coating? I am just worry about that and I had spent a lot of time for the prep.
    Thanks everyone!
  2. #2
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    Re: Applied 2x Optimum Gloss-Coat Paint, can Klasses AIO after?
    No need to use it. Stick with Gloss Coat and enjoy.
  3. Thanks goyard thanked for this post
    Likes goyard, dlc95 liked this post
  4. #3
    Super Member vobro's Avatar
    Join Date
    Jun 2012
    Location
    Homer Glen Il
    Posts
    1,156
    Post Thanks / Like
    Don't understand your logic here, why coat your car and then less than a week later put an aio on it? More is not better and makes no sense
  5. #4
    Newbie Member
    Join Date
    Apr 2019
    Posts
    2
    Post Thanks / Like
    Quote Originally Posted by vobro View Post
    I thought it will add another layer of protection on top of the coating. also more shine/glossy look.
  6. #5
    Super Member Nix's Avatar
    Join Date
    Jun 2015
    Posts
    297
    Post Thanks / Like
    Quote Originally Posted by goyard View Post
    nope..
    "You can avoid reality, but you cannot avoid the consequences of avoiding reality." - Ayn Ran
  7. #6
    Join Date
    Jun 2012
    Location
    Homer Glen Il
    Posts
    1,156
    Post Thanks / Like
    If anything just use the Opti-Seal on occasion. The way the GC will work best is to keep it clean and let it do its job, clogging up the surface with other products will impact the GC performance. Again more is not better and especially using a chemical aio on a coating that may or may not have fully cured is counter productive
  8. Thanks goyard thanked for this post
    Likes goyard liked this post
  9. #7
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    If you’re not satisfied with the shine/gloss
    that Optimum Gloss-Coat is providing, it
    can be “topped” with Finishing Sealants; for
    example: Optimum Car Wax and Opti-Seal.
    Note:
    Although Klasse AIO is not considered to be
    very aggressive, Klasse High Gloss Paint
    Sealant (K-HGPS)—a Finishing Sealant—would
    be more apropos in this particular case, IMO.
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  10. Thanks goyard thanked for this post
    Likes dlc95, goyard liked this post
  11. #8
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,780
    Post Thanks / Like
    ...especially using a chemical aio on a coating...
    This is a key point. Klasse AIO is a product with chemical cleaners designed to strip away anything on the suface of the paint it's being applied. Any traditional AIO would do the same thing, only with abrassives. You'd actually be removing some of the coating if you applied with Klasse AIO.
    Long ago, the idea was Klasse AIO was a prep product to be used in order to make Klasse Sealant Glaze bond better to the surface and last longer. It just happened to have some protective abilities, so people will use it as a stand-along product as well.
    Drop by to see the latest at The Car Geek Blog
  12. Thanks goyard thanked for this post
  13. #9
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    If you want to add another layer then stick with optimum products. Wash and get yourself some hyper seal (has to be ordered straight from optimum) to be your topper.
    I disliked opti-seal over Gloss Coat as it took away from the hydrophobic properties, self cleaning effect and overall performance away from Gloss Coat.
  14. Thanks goyard thanked for this post
Similar Threads
  1. mckees paint coat vs OPTIMUM GLOSS-COAT
    By Cruzscarwash in forum Auto Detailing 101
    Last Post: 03-11-2017, 09:30 PM
  2. Optimum Gloss Coat Paint Protection Performance Testing
    By Understated in forum Show N' Shine
    Last Post: 01-12-2016, 03:37 AM
  3. Replies: 15
    Last Post: 07-14-2015, 08:20 AM
  4. Optimum gloss coat paint coating
    By snellvilleauto in forum Products Guides
    Last Post: 04-02-2015, 01:49 AM
  5. Giveaway! Optimum Gloss-Coat Paint Coating
    By Nick McKees37 in forum Car Care Product Giveaways
    Last Post: 10-17-2014, 01:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» March 2024
S M T W T F S
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
