Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Re: Menzerna 3800 plus and Ruper coarse wool pad
    No big deal BUT I am going to merge the two threads.
    Done.
    You two threads have been merged into one thread. In the future, please only create one thread per topic.
    Thank you!
    Newbie Member Manilruben's Avatar
    Nov 2018
    My apologies will take care while posting .. thanks for correcting
  3. #13
    Nov 2018
    Quote Originally Posted by rlmccarty2000 View Post
    Kind of a weird choice using 3800 with the Rupes blue wool pads. I’m not really sure what you were trying to achieve. The wool pad is great for cutting and 3800 has almost no cut. Personally I would not use the two together, but doing a test spot to actually see the results is ideal. The blue wool and Menzerma 400 leave and almost LSP ready finish on some paints (surprisingly).
    LC Microfiber cutting pads and Menzerma 2500 works well for removing moderate defects depending on the paint. When using a wool or microfiber pad I always follow up with a foam finishing pad and a finishing polish to remove any haze. Again, let a test spot be your guide.
    The reason why I was asking Rupes blue foam pad and menzerna 400 did not do the job there was lot stalling and the rupes duettp was jumping with the pads
    Was wondering if I could use a more aggressive pad with a least cut polish would that end up in a better finish
    Thought of taking some advice from experts before I do something which I am not well versed with
  4. #14
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: Menzerna 3800 plus and rupes wool pad
    So you're sort of looking for maybe doing what's referred to as a "one step" polishing sequence.
    Get some extra cut from the more aggressive pad, and a good finish from the ultra fine polish.
    I tend to like using foam pads for that. The Rupes UHS system is EXCELLENT for accomplishing that goal. I also really like Menzerna PF2500 (or MC2500 as It's labeled today) on Lake Country Hydrotech Tangerine Polishing pads when using a Porter Cable 7424, or Flex 3401.
    However, one combo that I had a lot of use from is Rupes Keramik on their original yellow microfiber pads. It generally finishes great, and gets a nice amount of correction. On some paints, I have had it leave a haze - two black gm vehicles.
    Rupes Quarz (green) on green foam is another that I've successfully been able to one step on certain paints. In general I find the UHS to cut about the same, but finish out better. Same with the yellow microfiber + Keramik - cut about the same, but finished out better.
  5. #15
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Prime the Rupes wool pad completely. Take your finger and rub the polish over the face of the pad (not too much) and the pad won’t skip. I just used the pads and 400 with no problem. I prime microfiber pads the same way.
  6. #16
    Nov 2018
    Thank you so much I will try the UHS pads but not very sure will I able source one in India.
    The ketamik is with me thanks to Rupes they had packed it with the machine
  7. #17
    Nov 2018
    Thanks will try that ..is there are any other reason apart from not priming the pad which can lead to stalling
  8. #18
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Quote Originally Posted by Manilruben View Post
    An orbital will almost always stall on curves. Use a gear driven or rotary if you want to prevent stalling.
    Since you seem to be a bike kind of guy, get the Ropes Ibrid polisher.
  1. Menzerna 3500 , & 3800?
    By Indiglofish61 in forum Auto Detailing 101
    Last Post: 09-04-2018, 02:25 AM
  2. M105 on microfiber to menzerna 3800 ?
    By uhohitsstevo in forum Auto Detailing 101
    Last Post: 09-22-2017, 12:58 PM
  3. Menzerna 3800 Pad selection?
    By brunorio in forum Auto Detailing 101
    Last Post: 07-17-2017, 04:38 PM
  4. Menzerna Super Finish Plus (SF-3800)
    By dschribs in forum Auto Detailing 101
    Last Post: 01-26-2017, 08:21 AM
  5. sf-3800 vs rupes ultra fine gel
    Last Post: 01-13-2017, 05:17 PM
