Results 1 to 3 of 3
    Dec 2018
    How can I improve this touch up paint job?
    Hello,
    I had a small chip on my car. I applied basecolor, then few days later, I applied clearcoat. However clearcoat made it look worse. I did wet sanding with 3,000 grit but I think there is not enough basecolor under the clearcoat. How can I make this look better? Should I use rubbing compound or continue sanding until I remove the clearcoat?
    Please help.
    Thank you
    How can I improve this touch up paint job?-img_20181215_181022-jpgHow can I improve this touch up paint job?-img_20181215_181051-jpg
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Re: How can I improve this touch up paint job?
    The paint in the chip looks like it's still too high. You need to sand it down level with the surrounding paint. How much experience do you have wet sanding?? In the future Dr Colorchip is a lot easier to use. I can't really tell if the other issue I'm looking at is clear coat smeared across the top of the paint or sanding marks.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
    Dec 2018
    Quote Originally Posted by DaveT435 View Post
    If you notice, there is a white spot inside the clear coat. I think this is the metal. I'm trying to remove the clear coat so I can add one more layer of base color.
    I have sanded the area multiple times with 3,000 grit but it did not do much. Should I go with 2,000? I don't have much experience with sanding.
    The surrounding area is just my fingerprints marks.
  1. touch up paint
    By shaggymarc in forum Show N' Shine
    Last Post: 08-22-2014, 04:44 PM
  2. Need help with touch up paint
    By Paulyfe12 in forum Auto Detailing 101
    Last Post: 05-24-2014, 04:46 PM
  3. Best Touch up Paint?
    By delliot in forum Auto Detailing 101
    Last Post: 12-09-2013, 12:20 PM
  4. removing spot gloss touch up paint to expose original paint?
    By slacknh in forum Auto Detailing 101
    Last Post: 09-16-2012, 11:37 AM
  5. A question about 3 stage paint and touch up paint.
    By Silverstone in forum Auto Detailing 101
    Last Post: 08-27-2010, 06:59 PM
