Re: Wolfgang Paint Seelant DGPS 3.0 maintenance
Wish they bought a 16oz of DGPS3.0.
Can I use the Spritz Sealant as a drying aid?
Which product of there is good for foam guns and washes really good?
Originally Posted by acuRAS82
Deep Gloss Spray Sealant (Spray sealant)
Uber Rinseless (waterless and rinseless wash)
Instant Detail Spritz (QD)
If you want to limit what you buy, the Detail Spritz would be first to go. If you do waterless washes, the Uber is great, even if you do regular washes you can use Uber to soften the water and/or spray at waterless wash dilution once per panel as you dry to avoid water spots.
All three contain the same polymers as the sealant you’ve used. Good synergy.
I use all three of those products, mostly the Wolfgang Uber and my DGPS has lasted about 8 months. It is just about time for a new application but I was pleased with the longevity.
Spritz Sealant as a drying aid... some may have experience using it that way, but the directions call for 12 hours curing dry, so it seems counterintuitive to spray it on to a wet surface, so I’ve never tried.
The Detail Spritz and Uber are my drying aids for DGPS.
You can use Wolfgang Car Wash in a foam gun, but if you want extra suds you might try Blackfire Foamer with it. Note that if you’re using a QD or D156 as a drying aid, there’s not really a need to have a wash soap that leaves polymers behind. You can go with Meg’s Hyper Wash which is cheap and foams well and use the drying aid after.
^^^ Exactly. ^^^
An excellent synthetic spray wax to use as a drying aid on top of WDPS is Prima Hydro. In my experience they work very well together and are fully compatible.
Prima Hydro Wax As You Dry Spray, spray wax
If you want to stick with a QD as a drying aid, FK 425 also works great with WDPS. At $29.99 for a gallon (before any discounts) the price is also right.
Finish Kare 425 Extra Slick Final Body Shine, finish care quick detailer, ultra slick detail spray
Both of these products work well as drying aids for Uber rinseless too!
Al Schmidt
"Adventure, is a car called Riviera..."
Hi thanks
Thoughts on these as a package
Wolfgang DGPS 3.0
Detail Spritz 3.8L
Sealant Spritz 3.8L
Auto Bathe (for foam gun Kwazar Venus Pro+ Super Foamer 2 Litre)
I have 3 cars to do, all big cars
One will be sitting outside 24/7, one in carport and other in garage.
Do you think these quantities are right, will put 2 coats of DGPS 3.0 on.
Over here in New Zealand (and Australia) UV is at its worse.
Thanks again
Hi thanks
Wolfgang DGPS 3.0
Detail Spritz 3.8L
Sealant Spritz 3.8L
Thanks again
The gallons of Spritz’ will last you forever. Not a necessity, but can’t hurt.
If you are buying that large quantity because you plan to use them constantly, I highly recommend 16oz of Uber RW instead of 3.8L Detail Spritz from a cost perspective, but your call.
Hi thanks for that
Does Uber RW act as a detailer the same as Detail Spritz?
Can I use Uber RW in a foam gun?
Thanks
Hi thanks for that
Thanks
Uber can be diluted to QD, which could replace the Detail Spritz.
I’m not a foam gun user, but I do NOT believe Rinseless washes can be used in a foam gun. If you already plan on using the gun then you would need the normal shampoo.
Note that Rinseless wash can be used anywhere including in your garage or outside with no hose access (good for winter time)
Thanks
Uber can?
Rinseless
Waterless
Detail spray
Just dilute appropriately
Does Uber have any polymers?
Thanks
Uber can do all those things. It has some of the same polymers as DGPS and Spritz Sealant, just way less concentrated when diluted (enough to make it shine like a detailer and reinforce the LSP for a short time). A gallon or even a 16oz bottle will last through many cleanings. Can’t go wrong with it.
By Jim w in forum Wolfgang Car Care
Last Post: 07-04-2019, 11:31 AM
By Bigbwb in forum Wolfgang Car Care
Last Post: 05-23-2019, 09:15 PM
By fech in forum Auto Detailing 101
Last Post: 04-19-2008, 01:16 PM
By Gnarboots11 in forum Auto Detailing 101
Last Post: 06-08-2007, 01:47 PM
By quantim0 in forum Auto Detailing 101
Last Post: 02-09-2007, 09:29 PM
25 | 26 | 27 | 28 | 29 |
