Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Super Member Finick's Avatar
    Jul 2017
    885
    Re: Meguiars Ultimate Fast Finish vs Ultimate Wax
    ULW does not haze like a traditional wax. It can be removed within 5 mins (I would have to double check). It can be applied to the entire car and then wiped off. It needs to be applied real thin or else it will streak. I never had an issue with it being hard to wipe off. I have not used it in years.
    There is a new updated formula available now at most retailers.
    That’s good to know. I’ve tried it with a DA and by hand and every time it seems to streak around. Maybe letting it sit for 20-30 minutes is counter productive?
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by Finick View Post
    When I used it, I would apply it to the entire car and then come back where I started and wiped it off. I was using a 300-350 low nap microfiber. The other option is removing it panel by panel after a few minutes.
    I have experienced it streaking if I used too much or if the surface was warm. I am not sure if the new updated formula does the same thing. I heard UPW doesn't have the same issue but UPW will stain trim and ULW will not.
  3. Thanks Finick thanked for this post
    Likes AZpolisher15 liked this post
  1. Meguiars ultimate fast finish before qwik wax
    By indiMjc in forum Auto Detailing 101
    Last Post: 07-02-2020, 07:18 AM
  2. Replies: 7
    Last Post: 10-18-2018, 09:00 PM
  3. Meguiars ultimate fast finish
    By Richs66 in forum Auto Detailing 101
    Last Post: 05-12-2018, 02:07 AM
  4. Meguiars Ultimate Fast Finish over Ultimate Quik Wax?
    Last Post: 02-06-2018, 07:22 PM
  5. Meguiars Ultimate Fast Finish: New product testing
    By Eldorado2k in forum Product Reviews
    Last Post: 05-16-2017, 11:41 PM
