Re: Airplane Detailing at Autogeek - Using a one step cleaner wax
Originally Posted by
minirips2
Did he say what type of paint the aircraft has on it? It looks like it's had a re-paint at some point. There are many things that will have to be done to restore an airplane that has sat for a long time. Those old Hartzell steel hub propellers got my attention right away. Numerous AD's on those.
As far as my dad and I are aware it’s the original paint job. We searched thru the log books. You might be thrown off because of the left tank. It was replaced with another tank. The original was damaged. Good eye on the props/Hubs I will send those off for an overhaul and inspection when it gets closer to the annual date. Since they are 5 year or 500 hour inspection. All ADs are update now other than the props. This has been no easy project when trying to find parts.
MrRoo
That’s got single stage. Clear cut or M105 will work great. Been using clear cut recently with awesome results on single stage. I detail a lot of aircraft. The paint is super tough to buff. Best bet is using a rotary with wool pad at first. It will look great!!
Thank you for your input, I will probably stick with the porter cable route for right now. Reason being it’s all I have and I’m not sure I would be to comfortable using a rotary.
I used to own an aircraft propeller repair station. Quick story- one day a guy comes in with a pair of Cessna 310 props. He says "So and so annuals my plane, and he's the best. I'm sure these props will be cheap to overhaul." I told him to hang out while I disassembled them. I tear them down, and the blade bearings were so rusted the balls were not even round! it looked like someone had pressure washed the blade clamps which is a big no-no. I asked him if these props even changed pitch. I felt so bad for the guy that I didn't charge him for the disassembly. Hopefully he has a new IA now!
Guyb liked this post
Very cool project! Will be fun to follow you on your journey. Nice thing to do for your dad.
/Tony
I have a dumb question, I’m looking at the RejeX sealant and I see that it’s pretty picky on temperature. The plane is covered in a hangar now, so would it be fine to apply. Or does temps over 85 in general hurt RejeX?
If you are new to this and I am making an assumption that you are you really need to do a test spot first. Airplane paint is normally tougher than automotive paint so that Porter Cable with a One Step (AOI) May not cut the paint enough to give you the look you are hoping for. IMHO AOIs are for vehicles with minor marring and scratches, not correcting airplane paint. If you are going to put on a separate sealant anyway why not use a compound or a stronger polish then apply your sealant? I also would suggest you use microfiber cutting pads even if you still go with an AOI. I don’t know much about RejeX, but I would suggest Finish Kare 1000p over 845. Good luck and buy a ton of pads!
Some teasers for today. I will pull it out this weekend to foam cannon it, and add more shots. Now I’m off to work.
Looking Good Matt!
