Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
    Dec 2017
    480
    Re: Sealants vs Coatings
    Hi all thanks for your input, interesting.
    I don't have a machine to remove to recoat, so is the Can Coat the only product to use for this?
    I would like to try it. Is there anything out there that I could use.
    Thank you
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by fightnews View Post
    Thing that stinks with coatings is water spots
    Of all the coatings I have used (Cquartz, CQUK, Sonax CC36, Gloss Coat, Gyeon Syncro, PBL V2, Ameriarmour), I have not had a single issue with water spots. That includes the cars being dirty and being rained on. Even my mom's car that has CanCoat and is parked under a tree was never spotted from all the junk that falls from the tree.
    Quote Originally Posted by PeteT19640 View Post
    Thank you
    Pick some up. If it is still going strong there is no reason to remove it. Pick up some Gyeon Cure and you can maintain it for a longer period of time.
    You can polish later to remove whatever old CanCoat is still on the paint and add another fresh coat. Hand polishing should be able to remove it.
    You should also consider picking up a machine to machine polish. Makes the job a whole lot easier.
    If you are not ready to go the CanCoat route then perhaps the new Blackfire SiO2 spray sealant is something to consider.
    More vides on CanCoat
  3. Likes BudgetPlan1 liked this post
  4. #13
    Aug 2013
    Tustin, CA
    4,389
    Thank you
    Can Coat would be a great way to start! I use Can Coat on my wheels. It is very easy to apply!
    CJ
    Save the Manual!
  5. #14
    Dec 2017
    480
    Hi thanks again
    Can Coat can be polished by hand then reapplied.
    Does it have a maintenance e.g. spray say every 2 weeks. Bit like a spray wax over a sealant, I use Meguiars Ultimate Wax, with the Ultimate Spray wax every 2 weeks.
    Power to a machine is tricky for me.
    Thank you
  6. #15
    Regular Member h8dirtycars's Avatar
    Feb 2017
    153
    It' amazing how much you learn just by reading a thread that catches your eye.
  7. Likes RamAirV1 liked this post
  8. #16
    Super Member Cruzscarwash's Avatar
    Oct 2015
    Desert of California
    2,425
    I live in an area of SoCal with bad water spotting and paste sealants seem to do better with spotting then coatings.
    This is just as far as coatings are concerned with spots. When it comes to other like shine, durability and those type things the coatings last much longer.
    Sent from my Pixel using Tapatalk
  9. Likes PaulMys liked this post
  10. #17
    Regular Member GEM65's Avatar
    Dec 2017
    149
    I heard many good things about Sonax Spray Seal by locals here which claim will work better than my all time favorite sonax PNS & BSD.
    SONAX Spray + Seal, spray sealant, spray-on rinse-off
    i've got some coming in Sealants vs Coatings
  11. #18
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Quote Originally Posted by Powerman View Post
    Lots of hot sun and clear cot failure.
    Living in Texas and having a hi top van I can’t garage it. A year ago I had the second clear coat failure on the top followed by the clear coat failing on the side body panels a year later. Because of my disabilities I’m looking for ease of maintaince but primarily UV protection on plastic/fiberglass.
    When the clear coat fails on the non-metal areas it cracks and peals off in big sheets rather than the typical clear coat failure of turning milky white and degrading away.
    I’m planning on using a coating that claims it has uv blockers and a no rinse wash that also has uv blockers in it. I’m just not sure that the UV is causing the failure.
    Will a coating work better to preserve my paint? Is the sealant applied annually the way to go? I’m not able to strip the van, I have a hard time doing anything but wiping the sealant on and off the top, it’s not going to see the buffer ever after the last $3000 paint job.
    Am I doing the right procedure for the sun/heat/pollution that you find in Houston or am I just stuck repainting my 18 year old fan every 7 years?
    David
    Houston TX.
    In your situation I would definitely go with a coating. If you were closer I would help you out. IMO you should go over the paint with at least a finishing pad and a paint cleaner before coating.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  12. #19
    Oct 2015
    2,425
    Quote Originally Posted by GEM65 View Post
    They are only claiming 3 months, when PNS is 6 plus
  13. Likes GEM65 liked this post
  14. #20
    Dec 2017
    149
    Quote Originally Posted by Cruzscarwash View Post
    Thanks for chiming in, i forgot to mention the longevity Sealants vs CoatingsSealants vs Coatings
  1. Coatings and Sealants question
    By roadrunner255 in forum Ask your detailing questions!
    Last Post: 12-04-2019, 05:13 PM
  2. Sio2 Spray Coatings vs Sealants
    Last Post: 06-10-2019, 02:32 AM
  3. wax, sealants, coatings
    Last Post: 04-28-2018, 10:55 PM
  4. New Car Coatings or Sealants
    By WillSin865 in forum Auto Detailing 101
    Last Post: 04-14-2018, 01:32 PM
  5. Stacking Sealants and coatings
    By QuickCln in forum Auto Detailing 101
    Last Post: 07-26-2016, 06:29 PM
