Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Thread: Vacuum
    Nov 2015
    Los Angeles, California
    13,729
    Vacuum
    Quote Originally Posted by LEDetailing View Post
    Ridgid. Same one Eldorado2k usesVacuum
    I got the detailing package from Home Depot with longer hose and attachments.
    Yea buddy.Vacuum
    I just upgraded from the Blue Filter to this premium wet/dry easy clean Hepa filter. Supposed to be the best available.Vacuum
    I’m cleaning my vacuum right now including the hoses [all 3] and attachments so it can be like brand new. More importantly smell like brand new.Vacuum
  2. Likes PaulMys liked this post
  3. #12
    Super Member prin's Avatar
    Oct 2008
    Huntsville, AL
    264
    Re: Vacuum
    Thanks for the replies. I have a shop vac now. But I want something better
  4. #13
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Re: Vacuum
    My Metrovac is less powerful than my home Shark for twice the price. Shark actually makes a vac for vehicle use that is similar to my home vac. I don’t like cleaning bags. My last two home vacs were bagless and easier to maintain. I should have done my homework on the Metrovac. A wet/dry shop vac would have been better for my use and probably been more powerful/versatile. It does have the blower option, but it is too clumsy and slow to be of use to me (I just grab my battery blower). It also takes up more space than a normal shopvac due to its long design (I will wall mount it someday). I do like that it was made in the USA.
  5. #14
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    Re: Vacuum
    Yea buddy.Vacuum
    I have the same one. Mine is filthy and pretty beat up compared to yours. I don't have a HEPA filter because mine works in the garage and outdoors only. Is that filter washable or do you have to dispose of it once it is spent?
  6. #15
    Nov 2015
    13,729
    Re: Vacuum
    Quote Originally Posted by Route246 View Post
    Not disposable but the complete opposite.. This thing is supposed to be built like a tank and last a very long time as long as you take care of it properly, meaning tap it clean and rinsing it in the sink or with low pressure hose is allowed. No compressed air or high pressure water. If you can follow those directions it should last.
    According to everyone it comes nearly completely clean by simply tapping it clean. It’s coated with teflon or something similar.
    My Ridgid was as nasty as you can imagine prior to me cleaning it just now. I didn’t take any before pics but you all know how grimy it looks after a few wet carpet details.
    It is ready.
    Set!
    Mate!
  7. Likes LEDetailing liked this post
    Dislikes LEDetailing disliked this post
  8. #16
    Regular Member Sleper's Avatar
    Mar 2006
    120
    Re: Vacuum
    Shop vac 6 hp with the smaller 1 1/2 inch hose adapter. Works great and is inexpensive. have a crevis tool, carpet tool and and dash soft tool.
  9. #17
    Nov 2015
    13,729
    Re: Vacuum
    Quote Originally Posted by Sleper View Post
    You’re talking about this?
    It’s cool but it makes a crazy annoying high pitched noise when connected that way.
  10. #18
    Mar 2017
    1,037
    Re: Vacuum
    It is ready.
    That's pretty sanitary. Maybe I'll hit mine with the power washer and see if I can clean it up like that.
    On a side note, due to a lack of space, I'm thinking of getting a central vacuum system to bolt on the wall for the garage and cars. I have a place, out of the way I can mount it and then use 2" PVC vacuum pipe to run outlets in convenient places in the garage. I want power so I'm looking at a large house-grade unit. 50' hose is standard. Overkill for the garage and cars but I like building infrastructure like this. It would be nice to have an on-demand vacuum outlet right inside of the garage doors on both sides. I'm getting ready to redo my compressed air infrastructure so it would be two birds with one stone. My current compressed air system has some flaws that I want to correct, too.
  11. Thanks Eldorado2k thanked for this post
  12. #19
    Apr 2015
    PGH, PA
    1,482
    Re: Vacuum
    I'm curently using the mckee37 dual stage shop vac..185 cfm.
    Ill be adding another and get a Y adapter to run both at same time..
    Any 6.5 HP single stage motor will work well too as they range from 195-205 cfm
  13. #20
    Jan 2014
    SoCal
    1,122
    Re: Vacuum
    Powr-flite 100+ inches of lift.nothing that Ridgid makes (at least that I've ever seen) comes close to that.
    I have a Clean Stream filter on a Shop Vac that's been there 15-20 years. I've never washed it. I do occasionally blow it out with air. After reading Eldo's post, maybe you're not supposed to??? I've never had it cause any damage.
  1. 12v DC vacuum
    Last Post: 02-07-2017, 07:23 AM
  2. Looking for a vacuum
    By rightaway in forum Auto Detailing 101
    Last Post: 09-26-2015, 03:53 PM
  3. How much vacuum do I need?
    By 2BlackChevys in forum Auto Detailing 101
    Last Post: 03-13-2013, 10:51 AM
  4. Vacuum ?
    By van185 in forum Auto and Garage Accessories
    Last Post: 03-19-2012, 06:45 PM
  5. What vacuum do you use?
    By Garry Dean in forum Off-Topic
    Last Post: 09-15-2011, 08:35 PM
