Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Aug 2016
    S/E Wisc
    35
    HD speed by hand
    Anyone else try HD speed by hand. Tried a 1ftx1ft section. Put it on with a waxing pad, let it dry and wiped it off, buffing with a microfiber towel. Looks wet and really shines, the paint in question is black.
    Regards
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    Re: HD speed by hand
    Yes, I polished my door jambs with Speed.
    Dark metallic blue paint on my Pontiac TA. Same method, MF applicator, slick, glossy, removed light marring and most importantly, clean!
    Jan 2014
    SoCal
    1,122
    Working by machine is faster. But, that doesn't mean working by hand won't take you in the correct direction.
    If you find you want a little more correction, you could get some Meguiars Ultimate Compound (UC) and use that by hand prior to applying the Speed. I'm not saying do the whole car in one session with the UC. Just pick your spots and move the paint forward. A lot of guys here use the Megs UC in areas where they have to work by hand (Under door handles, under mirrors, in and around emblems, etc.)
    Super Member VISITOR's Avatar
    May 2007
    9,716
    working by machine is ideal because it will break down the abrasives (AIO) which will give you better results overall...
    Aug 2016
    S/E Wisc
    35
    Quote Originally Posted by LEDetailing View Post
    I mostly fool around with 60-70's cars and they have a lot of metal inside I think this stuff works great. Easy on easy off and it shines very nice. This is the only 3D product I have right now, But....I think I'm going to try some of their other polishes this week with my upcoming order here.
    Regards
    Aug 2016
    S/E Wisc
    35
    Quote Originally Posted by ducksfan View Post
    I just picked up a bottle of Ultimate compound this week that also is nice stuff used it on a truck lid that had a few deeper scratches in the clear coat with a white pad on that baby 3" from Groits that little machine works very nice now with the 3" thin pads from Lake Country. I almost threw the machine away when I first got it trying to make it work with 4" waffle pads, the thin 3" pads work very nice. Use it a lot on the interior metal on the older cars.
    Regards
    Feb 2011
    32
    I think HD Speed uses SMAT and not DAT abrasives. Thus, no breakdown occurs.
    Same as LEDetailing, I also use it on door jambs works great.
    Aug 2016
    S/E Wisc
    35
    Quote Originally Posted by sportsfan View Post
    Thanks that was going to be my next question is Speed and the other polishes from HD SMAT or DAT.
    Super Member LSNAutoDetailing's Avatar
    Jun 2014
    Chandler, AZ
    3,360
    Quote Originally Posted by anderson3754 View Post
    Per David Fermani (formerly with 3D Products):
    HD Speed is a combination of 75% HD Polish & 25% HD POXY. The abrasives are identical in both products
    Thus they are all Adaptive Abrasive Technology (AAT).
    Regarding using the product by hand? It's possible, you'll be at it a long time and will never achieve the results of a machine polishing as the product was intended. A hand cannot match the speed, rotation and orbit of a DA Polisher.
  10. #10
    Aug 2016
    S/E Wisc
    35
    Quote Originally Posted by LSNAutoDetailing View Post
    Hmmm..AAT... That's interesting, now I have another topic to become familiar with.
    Regards
  1. Stoner's Speed Bead Spray Wax vs Speed Bead Quick Detailer
    By AllenK in forum Auto Detailing 101
    Last Post: 07-29-2018, 12:25 PM
  2. Cyan pads and Flex go together hand in hand..
    By HateSwirls in forum Product Reviews
    Last Post: 02-08-2015, 02:01 PM
  3. How to use a hand applied abrasive polish or paint cleaner by hand
    Last Post: 07-22-2014, 06:19 AM
  4. Replies: 17
    Last Post: 03-23-2013, 12:13 AM
  5. Replies: 5
    Last Post: 11-11-2011, 08:10 AM
