Re: Can you recommend a medium cut polish for production detailing?
Originally Posted by mwoywod
The only problem i've found with the boss creams are that they can be EXTREMELY difficult to remove on soft sticky paint
Absolutely agree. I have another compound I use on soft paint.
On a side note, HD Polish does use non dimishing abrasives, but the BOSS creams do diminish at end of the buffing cycle(usually after 2-3 section passes).
As if abrasive technology wasn't confusing enough, the hot shots over at Griot's Garage just had to complicate everything further by introducing "non-diminishing, diminishing abrasives." lol
Is the "difficulty" in removal of BOSS creams on soft paint because it's literally difficult to remove (but the cc is fine after you get the polish off)? Or that it's difficult to not mar the soft paint when removing? (I Hope that question makes sense)
I am not sure if this was touched on, but I do mainly production detailing, and most times a coating is the LSP. The predicament can always be that alot of AIOs are silicone based and they are some what medium cut as well. I if found a few none or minimal silicone go to ones that work on at least Japanese and german paint well, however as we all know its a case by case. Meguiars D300, Meguiars M205 and Menzerna Medium Cut Polish 2500... But dont look at the buffing liquid it self, the pads makes a difference as well, so you will have to "play" with different combos to suit the paint and of course machine. I would say maybe about 5% of customers will take a swirl finder light and look into the paint! Once stuff shines its all that matters. Unless you are doing a "showcar" and being compensated on such. Hope this helps!
The first I read on agglomerated abrasives, was Todd Helme's initial write up of FG400 vs M105. Probably why FG400 always cuts so well for me.
It's literally difficult to remove, and when any polish is difficult to remove, you will marr the paint, especially soft. I use another compound on soft paint, it's much easier to remove. As a result, the chances of marring are much less.
I received a few samples of Correcting Cream and it is fantastic and is actually similar to HD Polish+ in the sense that it's extremely lubricated & offers a long buffing cycle, but isn't oily and wipes away clean. They both use non-diminishing abrasives and are 100% dust free. Personally, I think that correcting cream is a bit redundant considering how versatile Fast correcting cream is and even with a microfiber cutting pad tends not to leave much haze if any. The only problem i've found with the boss creams are that they can be EXTREMELY difficult to remove on soft sticky paint and I wish they would offer 32oz. bottles. Not sure why they only offer 16oz. and 128oz.
Does Correction Cream have any more cut than HD Polish+?
I've tried removing light scratches from my paint with HD Polish+ and it doesn't seem to have enough cut. That leads me to believe my paint is medium or hard, and so I think I'm looking for more of a medium polish, and Correction Cream seems like a good candidate.
I'm using a 7424XP, and 5.5" LC flat pads in white and orange.
The PC may need a lot more passes to correct.
That said, if the HD or CC isn't cutting it (pun intended), then Griot's Fast Correcting Cream may be your answer. And it finishes down just like a medium polish. Great stuff.
Fg400 finish very well. i use it with mf pads and results are very very good.
Last Post: 11-02-2018, 10:40 AM
Last Post: 07-06-2017, 02:18 PM
Last Post: 12-05-2014, 05:04 PM
By The Critic in forum Auto Detailing 101
Last Post: 11-14-2011, 02:47 PM
By john b in forum Auto Detailing 101
Last Post: 07-13-2010, 06:26 PM
