Results 1 to 4 of 4
    Jan 2017
    Coating Questions
    So my question has to do with coatings, I have always been a sealant guy but have become more and more interested in coatings. Now my question is, we all know you can only cut and polish a car so often before you run out of clear coat to play with. That being said, once you correct the paint and apply a coating, the coating will last up to a year or more they say. Once that time period has passed, obviously the coating won't wear evenly across the whole car and from what I've read the only way to remove a coating is to buff it off. So basically my question is, once you correct the paint and apply a coating, how do you service that vehicle again once the coating wears off without risking burning through the clear coat? Or once you apply a coating for a customer, should that turn into purely a maintenance customer as far as the exterior goes and once the coating has gone through it's life span just ends up beings a wash and wax or wash and seal?
    Thanks in advance!
    Nov 2016
    60
    Re: Coating Questions
    A simple hand wash will do it for some time but many manufacturers suggest you de-iron and clay the car every 6 or 12 months. That should revive the coating.
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    1,999
    I believe CarPro Essence+ is designed with this 'coating maint' purpose in mind.
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    You can absolutely re-coat a vehicle.
    We coat almost every vehicle that goes through our shop, and my personal vehicles are coated. For a well maintained car that does not need paint correction, we recommend a light polish as needed (generally every 1.5-3 years) followed by a new coating layer application. If the vehicle has superficial defects that need to be fixed, then clean and correct the vehicle as you would normally, then reapply the coating after the correction process.
    If you do not wish to reapply a coating, then don't. Just clean, polish, and seal or wax the car as you would if a coating had never been used.
    Retired Professional Detailer
  1. Coating Questions
    By jdbillin in forum How to make money detailing cars
    Last Post: 08-08-2019, 11:18 PM
  2. Coating questions...
    By RippyD in forum Auto Detailing 101
    Last Post: 02-04-2017, 12:22 PM
  3. PBL Coating Questions
    By 11Silverado in forum Auto Detailing 101
    Last Post: 03-14-2015, 02:29 PM
  4. Some questions on DG Coating
    By BTLew81 in forum Auto Detailing 101
    Last Post: 08-15-2014, 08:22 PM
