Results 1 to 7 of 7
    Jun 2016
    Flat Blue or Flat Black or Flat Crimson Hydro Tech Pad
    Hello,
    Questions is should I use a Flat Blue or Black Flat Pad or Crimson Hydro Tech Crimson pad?
    Here's what I'm doing.
    2017 Audi with Glacier White paint.
    Coming right from factory (not sitting on a lot), so the paint "should" be in good condition.
    Going to give it a good wash and clay.
    Then going to apply this finishing polish/primer because it's the hardening agent for the paint coating I'm putting on.
    Polishangel Invincible
    POLISH ANGEL ® | GLASSCOAT | INVINCIBLE PRIMER ? POLISHANGEL® CANADA
    This is the one I'm not sure which pad to use.
    Lake Country 5 1/2 x 7/8 inch Beveled Edge Foam Pads, buffing pads, Lake Country curved edge pads, polishing pads
    Lake Country Hydro-Tech 5 1/2 x 7/8 Inch Foam Pads 3 Pack - Your Choice!
    Then going to put on 3 coats of this paint coating:
    Polishangel Cosmic
    POLISHANGEL® | GLASSCOAT | COSMIC | MULTI COLOUR ADAPTION ? POLISHANGEL® CANADA
    Going to use the Crimson Hydro Tech for this one.
    I'm thinking I should use Crimson with the Invincible since they call it a finishing polish, but just want to make sure.
    I have a Porter Cable 7424XP and will be getting a 5" Lake Country backing pad.
    Thanks!
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: Flat Blue or Flat Black or Flat Crimson Hydro Tech Pad
    In the event the paint is not in good condition, maybe consider the Tangerine Hydrotech. Cut is just under the orange, and finishes like a black pad.
    Of the three you mentioned, I'd go with the Crimson Hydrotech. It offers the most rigity of the pads you listed, but is still very soft and smooth.
    Sep 2015
    6,281
    Quote Originally Posted by neocoma View Post
    Hello,
    Polishangel Cosmic
    Thanks!
    customsporty will answer that for you,he is a product user and he will know,hopefully he will chime in today to help you.
    Super Member lawrenceSA's Avatar
    Feb 2012
    Durban - South Africa
    1,713
    Of course there are no 'rules' when it comes to clear coat hardness, but I've worked on a lot of Audi's and most of them are 'hard paint'.
    If the paint is really in excellent shape and you may be able to get away with a finishing polish and crimson pad to do a bit of a clean up, but I'd suspect you may need to step it up to the tangerine pad, which is more of a polishing pad, given the hardness of the paint.
    Jun 2016
    Thanks for the suggestions so far.
    I don't mind getting a Tangerine pad for the finishing polish (and then a crimson for the paint coating).
    So my question would be "if' the paint is in perfect condition when I get it. Will using a Tangerine (instead of a Crimson) have any negative effects on my paint.
    Or will it just be an advantage "encase" there's any minor defects it will take care of it.
    I should also mention that the PolishAngel finishing polish/primer is a DAT style. Again, again not sure if that makes a difference.
    Thanks again!
    Feb 2012
    1,713
    The only way you will know for sure which type of pad will deliver the results you want, is by conducting some test spots - that is to take the LEAST aggressive combination of pad + polish and see what the results are. If they are up to your satisfaction, you don't need to go any more aggressive and can proceed to the protection part of the detail.
    If there are still defects in the paint you want removed after your initial test spot, then increase the aggressiveness of your combo (generally you would first increase the pad aggressiveness before moving to a more aggressive polish) and conduct another test spot. Repeat your test spots until you dial in a combo that removes enough of the defects.
    Let's assume for example that you had to step up to say a medium cut polish for the 'correction' work.... this may have left some hazing in the paint (remember the initial cut is effectively 'sanding' off the paint, and will leave its own fine 'scratch pattern' in the paint) and you could then switch back to your LEAST aggressive combo, and polish over your corrected test spot, to remove the hazing and maximize clarity.
    How aggressive you need to get will depend on the paint hardness and depth of the defects therein. Whether or not you need to follow up with a second 'refining' polish afterward will be dependent on how aggressive you had to get in the first step.
    Hope that makes sense and helps a bit
    Edited to add:
    Your test spot will only be on one section, and once you have 'dialed in' your combo, only then proceed to replicate this over the rest of the car. Don't go polishing the whole car with a combo you *think* will work, only to find out it didn't and you need to re-polish again.
    Jun 2016
    Cool. Thanks for the advice!
  1. Lake country hydro tech flat pads. Pads are ripping on my makita
    By Ncs0816 in forum Wool & Foam Buffing Pads
    Last Post: 10-04-2013, 08:38 PM
  2. More lc 5.5 flat pads or hydro tech bogos?
    By Ryan R in forum Auto Detailing 101
    Last Post: 04-30-2012, 09:47 AM
  3. Flat Pads or Hydro Tech Pads?
    By pcw25 in forum Auto Detailing 101
    Last Post: 02-15-2012, 09:19 PM
  4. HT crimson vs flat blue?
    By timaishu in forum Auto Detailing 101
    Last Post: 08-30-2011, 04:03 PM
  5. Anyone used LC Flat and Hydro-Tech cutting pads??
    Last Post: 12-27-2009, 09:40 AM
