Results 21 to 30 of 34
  1. #21
    Jul 2016
    3,328
    Re: Review: RUPES BigFoot LHR 19E Rotary Polisher by Mike Phillips at Autogeek
    Whats the theory on using a rotary like that on a factory clear coat though? Isn't that a big no no that will remove to much paint?
  2. #22
    Jul 2016
    3,328
    Is that the same car from the blackfire 1 step cleaner/wax thread?
  3. #23
    Super Member jslym777's Avatar
    Oct 2010
    308
    Quote Originally Posted by fightnews View Post
    you have to remove the same amount of paint, regardless of method, to remove the defects
  4. #24
    Good eye!
    Great question!
    But "no". Two different Chevelles, but both cool and both with BIG BLOCKS!
    If you go back and look at the pictures, while they look the same, one has a vinyl top and one has a painted top.
    wax.
    3-step
    I used this Chevelle for two reviews...
    Review: RUPES BIGFOOT MILLE LK 900E by Mike Phillips
    LOOK AT THE ROOF
    1-step
    Review: BLACKFIRE One-Step Cleaner/Wax by Mike Phillips
    LOOK AT THE ROOF
    Had a busy year last year.
    I'm going to try to post a picture of EVERY CAR that was detailed here in Autogeek's Show Car Garage. My guess is more cars, more write-ups, more reviews than any other forum and from any other "instructor".
  5. Likes mwoywod liked this post
  6. #25
    Common sense...
    Use the least aggressive process to get the job done"
    If a rotary is required or preferred, then simply use the least aggressive product and pad to get the job done.
    Good question....
    The rotary by itself won't remove too much paint. If >>>you<<< use it with an aggressive compound and an aggressive pad then it "can" remove too much paint.
    The key is to use the right tool, pad and product for the job. The rotary does in my opinion take the most time and practice to learn how to master.
  7. #26
    ***Update***
    Wow!
    Hard to believe we're about 14 days out from this review being ONE YEAR OLD!
    Here's the good news! The RUPES LHR 19E is now IN STOCK and READY TO SHIP!
    Get yours here!
    RUPES BigFoot LHR 19E Rotary Polisher Now in Stock & Ready to Ship!
  8. #27
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Mike, I’m curious as to where the stick handle is supposed to go. You showed it to go where the D handle goes. I found that too low for me and removed a plastic screw above(that holds the paddle head in place) and I liked it much better there. I’m sure it is ok there but curious as to an official answer.
    BTW the stick handle is extremely nice and comfortable. I’ll get a pic later when I get a chance.
    Jim
  9. #28
    Quote Originally Posted by Dr Oldz View Post
    The rotary in the pictures was an early production unit after it was revealed before SEMA in 2017 and at the time I had the unit to use and review there wasn't a stick handle with the unit.
    My guess is in the threaded hole shown in this picture here, either side but then again, this was a pre-production unit so things may have changed.
    Both sides of the head unit offer threaded holes for the stick handle or the bolts that attach the d-handle.
  10. #29
    Aug 2010
    NE PA
    4,462
    Is p
    In the above photos you will see what I mean. By removing the plastic screw and inserting the stick handle there, I find myself to better control the polisher. I sent an E-mail to Rupes for an official response.
    Also included a pic of the stick handle for those who may be interested in it. It is indeed really comfortable.
    Jim
  11. #30
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Mike, what is your take on the new Rupes wool pads? At first I was thinking they were more aggressive than microfiber pads, but after watching some Rupes produced videos I understand the wool pads remove less paint than a microfiber pad. I know from following you for years that you are not a big microfiber pad guy, but what do you think of the new pads and what is the cut difference between the blue and the yellow?
    Information like this is hard to come by.
  1. Review: RUPES BIGFOOT MILLE LK 900E by Mike Phillips
    Last Post: 07-13-2020, 12:34 PM
  2. Review: RUPES Mark III BigFoot 21 Polisher by Mike Phillips
    Last Post: 06-13-2019, 04:21 PM
  3. Replies: 2
    Last Post: 08-20-2018, 08:00 AM
  4. Review: FLEX PE14 Rotary Polisher by Mike Phillips
    Last Post: 08-17-2018, 09:30 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
