Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 68
  1. #41
    Nov 2018
    ARIZONA
    47
    Re: Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
    Thanks fellas!
    - Scott.
  2. #42
    ***Bump***
    For anyone "new" to machine polishing, check out the first page of this thread for a TON of info.
  3. Likes VISITOR, Oz_TCH liked this post
  4. #43
    Mar 2016
    The Jersey Shore
    80
    Save for later
    2014 Ram 1500 4X4 Big Horn QC True Blue
  5. #44
    ***Bump***
    Bumping for everyone that has purchased ANY orbital polisher or will be getting one for Christmas.
    Read through the entire first page
    and watch the video.
  6. #45
    Super Member Farmallluvr's Avatar
    Jul 2018
    Michigan
    507
    BUMPOLA ...always helpful
    “I have trouble with names and faces, but I never forget a car.”
  7. #46
    Quote Originally Posted by Farmallluvr View Post
    I agree, not just because I wrote it but because I know each and every day someone is getting a new polisher and buffing out a car starts with the brain, not the buffer.
    Here's another good article for anyone just starting out....
    DA Polisher Trouble Shooting Guide
  8. Likes Farmallluvr liked this post
  9. #47
    Nov 2018
    ARIZONA
    47
    Sorry again for bumping this old thread.
    Can any of you gentlemen advise typically how much AIO is needed on a typical pad?
    I'm using a Griot's DA with McKee's 360 on LC thin pro pads.
    I thought I remember reading somewhere on the forum that an AIO like 360 needs to be liberally applied to each pad.
    Is this accurate for the most part?
    - Scott.
  10. #48
    Quote Originally Posted by PSYS View Post
    Can any of you gentlemen advise typically how much AIO is needed on a typical pad? I'm using a Griot's DA with McKee's 360 on LC thin pro pads.
    Yes.
    You use a one-step cleaner/wax like you would use a compound or a polish when doing paint correction, that is you use the produt heavy or wet. You don't use a tiny amount. You want plenty of lubrication on the surface, plenty of abrasives plus whatever other magical ingredients any given brand uses to abrade paint and make it look beautiful.
    Here's a recent article I wrote with pictures to show you how to use an AIO
    How to correctly use an AIO or Cleaner/Wax by Mike Phillips
  11. #49
    ***Update***
    This article referenced here,
    How to remove oxidation - 1976 Sleekcraft Jet Boat
  12. #50
  1. How to machine clean a dry erase board by Mike Phillips
    Last Post: 10-08-2020, 03:39 PM
  2. Review: Machine Tire Scrubber by Mike Phillips - NO SHOCK HAZARD WHILE WASHING YOUR CAR!
    Last Post: 04-30-2020, 01:08 PM
  3. Replies: 11
    Last Post: 02-14-2019, 02:29 PM
  4. My Classic Car with Dennis Gage and Mike Phillips - Machine Applying Wax
    By Nick McKees37 in forum Autogeek on Velocity Channel TV
    Last Post: 12-06-2011, 09:51 AM
  5. For Mike - Principles of Machine Polishing DVD
    By Shane731 in forum Ask your detailing questions!
    Last Post: 04-06-2010, 02:14 PM
