Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Sep 2016
    Las Vegas, NV
    201
    Re: Carnauba dusting problem - What is the solution to avoid and protect our business?
    ONRWW is the best I have seen at not attracting dust.
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    Grounding the surface doesn't help? Get something like an iron nail or screwdriver and discharge the surface charge by touching the paint inside the door jams, hood and trunk jams and any other surfaces.
  3. #13
    Regular Member BryanH's Avatar
    Jan 2013
    California
    152
    Quote Originally Posted by ducksfan View Post
    Ok, so you've had the science. Now, as a practical matter, some posters have reported superior results with wiping wax and sealants with Meguiars Fast Finish. I have the product but haven't had the time to try it yet.
    Maybe those that have can comment.
    I'm in the midst of a little bit of testing regarding this. You might be referencing a video with a black Camaro in it? My theory after watching that video was that the "other product" (which I forget) was attracting dust, rather than Ultimate Fast Finish repelling dust. So I'm putting UFF to the test on a couple cars with a different control on each car.
  4. #14
    Mar 2017
    1,037
    When I put our dryer on a wood pedestal I noticed my MF was charging up like the balloon that sticks to your hair trick. I grounded the dryer to the cold water pipe and the static was greatly reduced. You MF may be inadvertently charging your paint.
  5. #15
    Nov 2015
    Los Angeles, California
    13,729
    Quote Originally Posted by BryanH View Post
    That other product was Carpro Ech2o.
  6. #16
    Quote Originally Posted by Kamakaz1961 View Post
    Thank you for your explanation of this Mr. Phillips! Keep on ROCKING!
    Thanks bud...
    Quote Originally Posted by KirkH View Post
    That was a DAMN good explanation, Mike!
    Thanks Kirk...
    Meaty post there, Mike!
    Thanks!
    I was aiming for meaty...
    Quote Originally Posted by AKT View Post
    What if we use a wash and wax product (ie ONRWW) and gently do a wiping motion when cleaning and drying? Much like a negative rep when lifting weights (go SLOWLY).
    This way, there is little to no "rubbing" therefore there will be little to no change in static charge of the paint.
    I would think the above at a minimum would help...
    Quote Originally Posted by GSKR View Post
    Never really have that problem.
    Maybe the humidity here in South Florida?
    Quote Originally Posted by mdrees View Post
    Sovereign liquid wax is awesome stuff but attracts dust like no other wax.
    Love the wax and never noticed the dust issue myself?
  7. Likes dlc95 liked this post
  1. Family Problem Solution
    By blackmagic5 in forum Off-Topic
    Last Post: 12-28-2016, 07:47 AM
  2. my problem, and in need of a solution
    By guess23959 in forum Ask your detailing questions!
    Last Post: 06-05-2011, 09:24 PM
  3. What would you do??? Business issue/Maintenance Problem.
    By Bates Detailing in forum Off-Topic
    Last Post: 02-20-2011, 07:34 PM
  4. Menzerna SIP dusting problem
    By LegacyGT in forum Auto Detailing 101
    Last Post: 09-18-2010, 10:06 PM
  5. poorboys SSR 2.5 dusting problem solved!
    By drdellorama in forum Auto Detailing 101
    Last Post: 04-24-2007, 09:22 PM
