Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Feb 2017
    Re: Rupes 5 Inch 2000 & 3000 Grit Sanding Discs
    You need to maintain pad rotation.
    So mark your backing plate so your eyes can see pad rotation and then adjust the speed dial as needed to maintain pad rotation.
    So, this applies when I'm sanding with those 9mm orbit machines, too? I need to increase the speed until the sanding disc starts to rotate? Or this only applies when compounding / polishing?
  2. #22
    Jun 2009
    Stuart, Florida
    36,722
    Quote Originally Posted by pepeleascov View Post
    My experience is you want to see pad rotation for effective sanding or paint leveling.
    If the sanding disc is simply vibrating against the paint then "yes" it will remove paint because pointy sharp particles of grit when pressed against car paint and jiggled are going to have an effect.
    But rotation of pointy sharp particles of grit when pressed against car paint will remove paint faster and my guess is leave a much more uniform sanding mark pattern for buffing out.
    What are you working on?
    What tool are you sanding with?
    What sanding discs are you using?
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  1. Video: Wow! 3M #5000 Grit Polishing I mean Sanding Discs!
    By Mike Phillips in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-13-2017, 12:02 PM
  2. First time wet sanding kit - #3000 & #5000 Trizact Sanding Discs
    Last Post: 02-03-2017, 08:53 AM
  3. Using Meguiar's 3000 grit Unigrit Finishing Discs
    By kerenzv in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-02-2013, 05:38 PM
  4. 3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459 - Singles
    Last Post: 05-22-2012, 11:16 AM
  5. Replies: 10
    Last Post: 07-30-2011, 12:52 AM
» August 2017
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
