Re: Griot's Garage NEW BOSS Paint Polishing System
Originally Posted by Legacykid
As a skeptic I am watching the videos on the GG youtube. In one video Mr Brown used a MF cutting pad and correcting cream. and the after shot was perfect. Was this a slip up, or was it not mentioned that it was followed by a polish after. Or is this the lacquer paint?
Also have you used the pads and the creams? The pads are thinner than average. and I know older GG polished and compounds were not the best.
Correcting Cream is very similar to HD Adapt IMO. I'll have to check the video you're referring to but I would expect most paints to have some very faint DA haze when used with a MF pad, but on some harder clears it could finish LSP ready. I would typically follow it up though.
Yes, I've had the pads and creams since December, though there have been changes along the way. The pads are only 8mm thick, so yeah, a lot thinner than the pads in the past. I never used any of the Griot's polishes prior to this, only tried a few items like BOS Wax and Speed Shine. I know a lot of time went into developing this new polishes at their state of the art laboratory and I feel they have released a very solid line that will perform just as well as the rest. Compounds and polishes all seem to have different attributes that they excel in, you just need to decide which is most important you. The low dusting, long working time, and great finish of the BOSS polishes are what I like most.
Jeff and I actually used Correcting Cream with a MF pad on this paint. It looked 95-98 percent LSP ready, but we still followed it up with Finishing cream to remove any faint DA haze that remained.
I am sure its a great tool. However, its not dramatically different from the Rupes, or dramatically less expensive. Thats a tough argument to make for me, especially considering its made in China (from what I read).
I also have a theory which may or may not be correct. All the tool makers could put as much or little power into their machines as they want. There must be a reason why Rupes only uses a 500watt motor. My theory is Griots products and tools are targeted for the do it yourselfer mostly, and therefore they use more powerful motors in their tools to compensate for poor technique that end users of their tools most likely will have as they are not professionals and probably do not use the tools that often.
Having said that, when I first started in this addiction 4-5 years ago, there were just a few options for tool. Now there are a bunch, and choice is always a good thing!
You are exactly correct. The Griots PC is a perfect example. Try using speed 6 on it. Melts your pads in no time. It is as effective at speed 4 as the Porter Cable at speed 6. So all that power may never be used but looks good on paper I guess?
Super Moderator
Originally Posted by Firehouse Mike
I think I have video of that, I will try to post!!
Thing is, that wattage isn't necessarily a benchmark of how much power the device outputs, it's simply a measure of the rate of power drawn which can include heat loading of the equipment. You also don't know if that's peak or running wattage. Without a soft start i's possible that the only time 900 watts is in play is when the trigger is first pulled.
It's quite possible that the Rupes has a much more energy efficient motor and different gearing and is making more power to the spindle at 500 watts than the Griots does at 900. I don't think any of us here that aren't staring at engineering prints can make comparisons at that level.
Having watched GG's videos and listening to Jeff Brown explain the BOSS system, I'd say they are now going after professional users.
This system looks absolutely FANTASTIC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
These polishers are NOT off the shelf Chinese units. They were built from the ground up using high quality parts. Also, the polishes are made in house from Griot's; no relabeling. They're supposed to be great! They utilize SMAT technology which I prefer. Pads looks awesome, too.
I think Griot's hit a HOME RUN with this system.
I don't think anyone is saying it's dramatically different. Is there anything dramatically different between all the rotary polishers out there? They all look pretty much the same to me, yet there are several slight nuances between them all that can make a big difference in how it feels in your hands and performs.
These tool are targeted for both intermediate users (those wanting to step up from an 8mm tool) and professionals. I believe this was touched upon in the Griot's videos and at the Griot's release. It's one of the main reason's it ships without the washer installed but still includes it in the tool pouch.
How about I break things down a little and see if this helps compare the differences/improvements. I'll give 1 point to the tool I feel is the best at that feature and 0 for a tie and explain my thoughts for each where I feel it's needed. Obvioulsy a lot of these are subjective
Power Cord: Tie
If this one was based of my Rupes, which was from the first batch of tools into the US, Griot's would win. However, it appears Rupes has since changed the cords as my LHR75e is much better than my LHR15/21.
Main handle Grip: Groit's (1)
Both in form and comfort, Griot's wins hands down. It just fits better in your hand and the soft double shot rubber grip is great.
Instant On Start: Griot's (1)
Rupes uses a slow start
Variable Speed trigger: Griot's (1)
N/A for Rupes
Speed Control: Griot's (1)
Nice solid feel and click from speed 1 to 6 with a bump in power at each step (1,1.5,2,2.5, ect...)
Speed Lock: Griot's (1)
Much more ergonomic on the Griot's tool
Quick Access Brushes: Griot's (1)
N/A on Rupes
Replacement Brushes: Griot's (1)
Main Body Rubber grips: Griot's (1)
Rubber Grip on Polish Head: Griot's (1)
Allen wrench holder on tool: Rupes (1)
SS (Kevin Brown) washer included: Griot's (1)
Power: Griot's (1)
I'm no electrical engineer but here is my $.02 on this. I feel listing power ratings of the motor on these tools is mostly marketing, and IMO unnecessary. 900w vs. 500w doesn't mean it has almost twice the power and it's not the same as 500hp in one car and 900hp in another. However, having seen both motors and used all 4 tools, the Griot's uses a noticeably beefier motor and at the end of the day the Griot's definitely has more power and is less likely to stall over the contours.
Tool Vibration: Tie
No noticeable difference
Weight: Rupes (1)
Sound/Loudness: Rupes (1)
This one could almost be a tie as I feel the sounds of the Rupes is higher pitched and less pleasant to listen too, but I think the over all volume (db reading) of the Griot's would be louder. I never measured this though and my hearing sucks!
Backing Plates: Tie
I think the Rupes is a very solid backing plate but I also like the cooling feature of the Griot's and it's pretty solid as well.
Warranty: Griot's (1)
Interchangeable backing plates: Tie
Over build quality, feel, and construction: Griot's (1)
This should be pretty clear for anyone after holding each tool
So based on the above:
Griot's - 13
Rupes - 3
Power Cord: Tie
N/A for Rupes
N/A on Rupes
Power: Griot's (1)
Tool Vibration: Tie
Weight: Rupes (1)
Backing Plates: Tie
Griot's - 13
Rupes - 3
It's RASKY speaking. 'Nuff said.
His post alone should be take with HIGH integrity. Honestly.
Chad--IMO you've done a fantastic job of evaluating the new polishers and keeping an objective eye open!!! Thanks!!
Last Post: 08-18-2018, 01:02 PM
Last Post: 07-08-2015, 08:04 PM
By Brownie in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 06-12-2015, 11:31 AM
By Brownie in forum Hot topics & Frequently Asked Questions
