Results 11 to 20 of 25
    Super Member Johnnyboy's Avatar
    Oct 2010
    Miami, FL
    201
    Re: Tips for working in warm/hot weather or direct sunlight
    Good info Mike! I work in the sun when working on the cars and I have a way of putting up an 11' x 16' tarp instead of a canopy but thats because I work in the same area everytime. Because of possible contamination from the wind and the elements, after prepping the paint and before I get into polishing, I wipe down the panel with a quick detailer to make sure nothing has been blown and landed on the paint.
    Quote Originally Posted by ixnod View Post
    more important than what you are working on, everyone need to stay cognizant of their hydration level and symptoms of heat stress,cramp, stroke. which are exasperated by lack of circulating air and the accumulation of chemical fumes ( Read the MSDS)
    Good point... keep plenty of cold bottled water on hand and take water breaks often when working in warm and hot conditions.
    Quote Originally Posted by Johnnyboy View Post
    Was showing that tip this last weekend at out Detailing Boot Camp Class, that is wiping the paint down after the compounding step to make sure all fragments from the compounding process are removed before staring the polishing step.
  3. #13
    Dec 2013
    HMMMM.. Please help with tips and tricks for working with -8 degrees.... Arrrgghh... Mike, please have a contest where the lucky winner (from the north) gets a trip to Florida for one of your detailing classes!
  4. #14
    Quote Originally Posted by OSP1560 View Post
    I heard someone mention a contest for a trip to Autogeek to attend one of my classes, not sure what happened to the idea?
  5. #15
    Super Member HUMP DIESEL's Avatar
    Dec 2013
    Gaffney, SC
    930
    Here is my take, since I live in South Carolina, we get some hot summers where we have lots of humid days where even walking out causes you to sweat, I am sure Mike can relate being in Florida.
    Most of my post keep going back to when I had my mobile business, so here are my tips. *This is for the person or persons who have a totally contained unit.
    1. Buy a good canopy. I have an EZ-up Contractor grade that is big enough to park a Hummer under. It has saved me more times than not when it is really nasty hot outside. (One caveat here is that I had helpers)
    2. Hydration: We always and I mean always had a full size cooler with hydration drinks, water and snacks. I cannot stress enough how much electrolytes you will loose on summer days.
    3. Limit your exposure. Where lighter fabrics with full sleeves, wide brim hats help as well.
    4. Working product. This is where I have to take a side and say that we rarely did full level correction on anything without the use of either the clients shop or another shop. I would do a wash and wax on these days and that is about it. My money was made in washes and convenience service, not full correction detailing.
    HUMP
    By the way, if anyone is living close enough to me that they would want to come and check out the canopy, I would sell it. Message me and we could set up something.
  6. #16
    Quote Originally Posted by HUMP DIESEL View Post
    1. Buy a good canopy. I have an EZ-up Contractor grade that is big enough to park a Hummer under. It has saved me more times than not when it is really nasty hot outside. (One caveat here is that I had helpers).
    Have a good way to anchor it down to in case it's windy outside. I've used 5-gallon buckets with water in them, at 8 pounds a gallon a 5-gallon bucket weighs 40 pounds.
    Don't tie them to the canopy with rope as this will just cause the buckets to spill, instead use a bungee cord because it will stretch. If you can park your rig next to the canopy and somehow use the weight of your rig to anchor the canopy down. The big picture is you don't want your canopy blowing around possibly damaging a vehicle.
    Two great tips...
    Another great tip, focus on doing simple work as in Keep it Simple Simon....
    Thanks for your contributions to this article HUMP...
  7. #17
    Regular Member chrislorl's Avatar
    Oct 2013
    103
    Great write up Mike, Thanks. I have been putting what you taught and what I have learned here to good use, but this heat in Central Florida is killing me. Product dries way to fast and act's differently. I look forward to the day I can build the garage and wash bay.
  8. #18
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    The very few times i have been forced to work in the direct sun of FL, i do 2 things: cover the next section i am moving to with a WW MF towel and top that with a "cooling pad". I have two cooling pads that are designed to be rinsed in cold water, wrung out and draped around your neck. Does wonders to keep me cooler in the brutal hot sun (with frequent rinses!). I will use one of them to lay on top of the MF towel to keep the next panel section cool.
    The second thing is like Mike said...i work smaller sections.
    This is mainly an issue with top sections as i can move the vehicle to get the sides out of the direct sun.
  9. #19
    Super Member VP Mark's Avatar
    Jul 2012
    2,451
    Great post Mike. Hopefully this will help out with many of the questions people have been asking on this topic.
    Sent from my SAMSUNG-SM-G900A using AG Online
    Visual Pro Detailing - Auto Detailing near Marion, IL. Call
    (618) 983-9706 www.visualprodetailing.com
  10. #20
    Super Member Tato's Avatar
    Nov 2013
    Brazil
    2,157
    I have a question:
    Generally, while polishing, I may stop immediately if I touch surface and feel it's becoming 'damn hot'. A little heat may be expected, but I never let it raise to the level of a 'full sun over a black car' feeling, if you know what I mean.
    My question is about this: I stop polishing if heat is building up fast, how to deal when polishing a surface that is, from the start, 'damn hot'?
    Wouldn't this increase (a lot) the potential burn of paint?
    I mean, I'd be really scared running a compound over a 'damn hot' paint, even if product states it can be used under full sun.
    On my reasoning, the product drying fast would be not my main concern..., since all those tips seems to deal with this issue in a efficient manner.
    Thanks in advance for help,
    Kind Regards.
    ― Isaac Newton
  1. Haze when in direct sunlight
    By pexle81 in forum Auto Detailing 101
    Last Post: 01-28-2019, 04:28 PM
  2. Direct sunlight ?
    By mikesal57 in forum Auto Detailing 101
    Last Post: 08-10-2013, 11:32 AM
  3. Wax for direct sunlight
    By Mercedes350 in forum Ask your detailing questions!
    Last Post: 05-26-2013, 09:28 AM
  4. Claying in direct sunlight?
    By Judge in forum Tricks, Tips and Techniques
    Last Post: 04-24-2013, 10:17 AM
  5. wdgps in direct sunlight?
    By unclestu in forum Auto Detailing 101
    Last Post: 11-17-2009, 04:35 PM
