Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 104
    Super Member turbos17's Avatar
    Dec 2006
    Downey (Southern), CA
    511
    Re: How to clean your foam pad on the fly
    Hey Mike I just tried the cleaning the pad on the fly with the Terry cloth and WHOA it worked. What is the ideal speed you should set it at when you do it? I don't want to trash my new pads I just got!
    Quote Originally Posted by turbos17 View Post
    I use the 5.0 speed setting, just be sure you don't turn the polisher on till your ready and one of your hands is holding the towel firmly against the face of the pad.
    Then take and move the towel over and against the pad while the machine is on, I also squish the towel into the pad at the same time.
    Remember, the idea is to somehow find a way to remove spend product and excess liquid out of the pad so you can QUICKLY get back to work, thus the portion of the title of this thread and this technique...
    on the fly
    It already takes enough time to detail a car so this is a technique to help you clan you pad a little and get back to work.
    It's also not called,
    "The BEST way to clean you pad"
    It's not the best way, it's simple a way most people can clean their pad a little and then get back to work .
    Note: I wrote the original version of this article back in 2005, (I think), and it was back when all we had were the first generation PC's and they had and still have a hard time keeping a pad rotating when the pad starts to get wet with product.
    Also, you don't want to work dirty, that is continue to use a pad with built-up product on the face of the pad for a bunch of reasons that I should have already talked about in the first post of this thread.
    Make sense?
  3. #13
    Dec 2006
    511
    ^ Perfect! I did it on the 5 setting for only 20 secs and it removed a lot polish, buildup, etc. I will try it for longer. And you are right that it doesn't leave any lint or fibers on the pad. Lucky for me I just bought the 6-pack from Lake County...I have plenty of pads for a vehicle now!
  4. #14
    Thanks for the follow-up, it's always great to hear the information on our forum has helped someone in their garage!
  5. #15
    Nov 2009
    Pasadena, CA
    12,615
    I'm assuming this speed and method will work with the Flex 3401?
  6. #16
    Dec 2006
    511
    Quote Originally Posted by 07 z-oh-6 View Post
    Any DA polisher! I have even used my old PC @ speed 6 and boy did my arm get a workout holding the towel. LOL!
    2005 Toyota Tacoma Pre-Runner
    aka "Storm Trooper"
    "Car waxes and paint sealants are to men like shoes are to women, you can never have too many" - Mike Phillips
  7. #17
    Super Member zinc02gt's Avatar
    May 2009
    Ozark, AL
    489
    Lay it on the ground and use your feet to hold down the corners. Yes, this technique only allows you to use one side of the towel, but I wouldn't clean on the fly with the same pad more then twice anyway.
  8. #18
    Quote Originally Posted by zinc02gt View Post
    I've never done it this way and never seen it done this way, seems like you would really be bending over as far as you could to hold the face of the pad against the towel. Besides that the ground is hard and flat and part of the cleaning action from cleaning your pad on the fly comes from your hand squeezing the pad somewhat with the towel. But hey if that method works for you then it's the right method.
    And for anyone reading this, just to explain, if you place one side of a towel against the ground it would now be contaminated with dirt and abrasive particles that you wouldn't want to hold against the face of your buffing pad and you would want to hope would wash out 100% clean in the washing machine.
    How often I clean a pad on the fly just depends upon how many pads I have to work with, I only have one cleaning or polishing pad I'm going to be cleaning it over and over again.
    The towel will get used up and you'll want to replace it often, kind of depends upon how large the towel is. Hand towels size work pretty good like the ones I show on page 1 of this thread.
  9. #19
    Nov 2009
    Pasadena, CA
    12,615
    When using a dual action polisher to remove below surface defects with any type of abrasive product you’re going to have two things building up on the face of the foam pad that you need to clean off.
    • Spent residue - From the product you’re using.
    • Paint - Small particles of paint that are coming off the car as you abrade the surface
    If you’re working on a clear coat finish then keep in mind you won’t see the paint residue building up on the pad because the clear coat paint is clear.
    Make sense?
    If you’re working on a clearcoat finish, all you're going to see is the color of the product that you’re using. For example if you’re using a white colored polish you’ll see white residue building-up on the pad.
    Now if you’re working on as single stage paint then you’ll see the color of the paint on the car on the face of your foam pad,. For example if you’re working on a single stage yellow paint system then you’ll see yellow paint on the face of your foam pad.
    The important thing to understand is that as you work on the car with your polisher you’re going to be removing a little paint and there’s going to be used-up product and paint building-up on the face of the foam pad. It's important to clean this gunk off your pad often.
    So the question is, how to you clean this gunk off the pad?
    The answer is there’s a number of ways to clean your foam pad, the three most common are,
    • Pad Washer
    • Nylon Brush or Pad Cleaning Brush
    • Terry Cloth Towel
    Out of the 3 options listed above, cleaning your pad on the fly is probably the most popular because it’s fast, and most people have a terry cloth towel in the linen closet that they can use to clean the pad.
    The best way to clean a pad is with a pad washer but before you can use a pad washer you must first own one. Pad washers are worth their weight in gold if you buff cars out with any kind of regularity. If however you’re just buffing out your own personal cars, then chances are you don’t own a pad washer but chances are very good you do own a terry cloth towel or two that you can use to clean your pads on the fly.
    Brushes work good if you’re using a rotary buffer but the only way you can use one with DA Polisher is to turn the polisher off, hold the polisher and pad in such a way that the pad won’t spin and then rub the brush over the face of the pad to scrape off the residue.
    While this works, it means turning the polisher off, (now you're not buffing out the car, remember the time issue?) and grabbing your brush and then brushing the pad. Nothing wrong with this but when you consider how long it already takes to do the cleaning step, (about 4-6 hours for an average size car and that’s if your good at this and if you work fast and don’t take any breaks. So stopping the polisher and using a brush to clean the pad works but it’s not as fast or effective as using a terry cloth towel.
    The whole idea and success behind the cleaning your pad on the fly technique is in that it allows you to clean your pad quickly, (that’s the on the fly part), and then quickly get back to work.
    Again, buffing out an entire car using a dual action polisher from start to finish is an all day job. There is no time for lollygagging. If you lollygag or take long breaks, you either won’t get the job done in one day or you’ll sacrifice doing a quality job during the cleaning step in order to get to the waxing step so you can put the car back into service.
    So let’s take a look at how to clean your pad on the fly
    Cleaning your pad on the fly is where you take a terry cloth towel, usually a medium size hand towel works best, you fold it in two and then simply hold the towel against the face of the pad and then turn the polisher on and use your hand that’s holding the towel to push the towel into the foam. This will act to draw any excess liquid out of the foam and any excess residue off of the face of the pad.
    After polishing a section of the trunk lid on Harvey,
    Max's classic 1964 Ford Falcoln Future, we took a brand new 100% Cotton Terry Cloth Towel and held it against the face of the foam pad and then turned the polisher on and pushed and smooshed the towel against the pad for about 45 seconds or so and here are the results.
    Question: Why use terry cloth instead of microfiber?
    Answer: Great question!
    100% cotton terry cloth is very good at absorbing liquid, so when you push the terry cloth into the foam the liquid in the foam will transfer into the terry cloth fibers through capillary action where the cotton fibers will more or less hold or trap the liquid inside of themselves.
    There’s more to it than that however, the nap of terry cloth, that is the little cotton loops, will help to slice into the caked and gummy reside which will loosen its hold so the residue will transfer to the towel as well as some will fall to the ground.
    Compared to most microfiber polishing cloths with a nap, not the type that has flat woven surface, the terry cloth nap, (the nap is the the little tiny loops of cotton fiber), is more stout and it’s this extra stoutness that enables a large, nap terry cloth towel to work better to break-up the residue on the pad.
    So it’s both the absorbency of the cotton fibers plus the larger size of the cotton nap that together make a terry cloth towel better for cleaning your pad on the fly.
    Does that make sense?
    The nap of 100% Cotton Terry Cloth Toweling
    Conversely, isn’t one of the reasons microfiber polishing cloths are so popular for wiping paint is because the fibers are microscopic in size and thus are more gentle to paint than larger cotton fibers? (The answer is “yes”)
    You can use what you like and make up your own mind. Besides the case I’ve made above for using terry cloth another reason is to save your microfibers for where they excel best and that’s wiping residues off polished paint.
    Some might also make the case that 100% cotton is better at absorbing while microfiber materials are better at adsorbing but that’s probably getting just a little too deep for what is actually a very simple method of cleaning your foam pads while buffing out a car.
    Try both the next time you’re working on a car and come to your own conclusion but for me I’ll use terry cloth towels for removing residues off my pads and I’ll save my microfibers for carefully cleaning residues off paint.
    Question: What about pad cleaning brushes?
    Answer: I touched briefly on this above, but let's drill down a little deeper. Pad cleaning brushes or even a nylon toothbrush work great for cleaning residue off the face of a foam pad when the foam pad is on a rotary buffer but they don't work well at all when the pad is on a dual action polisher.
    About the best you can hope for is to clean the very center of the pad when the tool is turned on but as you draw the bristles of the brush towards the outside of the pad the increased pressure over a small area, (the bristles of the brush pushing down on the foam), is enough pressure to engage the clutch in the tool and stop the pad from rotating.
    The brush only cleans the pad if the pad is rotating. Thus brushes don't work well for cleaning pads on dual action polisher when you're trying to clean the pad while the polisher is turned on. Give it a try sometime and you'll see exactly what I mean.
    For years when someone asks about the cheapie rotary buffers you can buy at Harbor Freight for buffing out paint, I would always mention that if nothing else, they make a great pad cleaner. That is take your dirty pads and one at a time place them on the backing plate of the rotary buffer and then use the rotary buffer to clean your pads. Rotary Buffers are direct drive tools and have a lot of power and a little brush held against the face of the pad isn't enough to slow the tool down so they work great for cleaning pads as well as removing a lot of paint quickly if you're using a RB to buff-out paint.
    The cleaning your pad on the fly technique works well for all the popular dual action polishers on the market including,
    • Porter Cable 7424XP
    • Porter Cable 7424
    • Porter Cable 7336
    • Ultimate Detailing Machine – The first generation was Autopia’s design. The second generation is a re-badged Porter Cable 7424
    • Meguiar’s G100a – Re-badged Porter Cable 7424, came with a lifetime warranty
    • Meguiar's G100 – Re-badged Porter Cable 7424, came with a 1 year warranty.
    • Meguiar’s G110 – Meguiar’s design
    • Meguiar’s G220 – Meguiar’s design – 220 Volts
    • Griot’s Garage Professional Random Orbital Polisher – Griot’s design
    Products mentioned
    Dual Action Polishers
    Porter Cable 7424XP
    Meguiar’s G110
    Pad Washers
    System 2000 Pad Washer
    Grit Guard Universal Pad Washer
    Pad Brushes
    The Edge Foam Pad Conditioning Brush
    Duo-Spur at Autogeek
    Cobra Detailing Brush Kit
    Further Reading
    Tips & Techniques for using the Porter Cable 7424XP
    Resources
    Autogeek Online Detailing Forum
    Autogeek Online Store
    Mike,
    How did you get a perfect circle on the terry cloth towel? When I tried it, the other parts of the towel would get wrapped up within a second of turning the polisher on.
  10. #20
    Super Member A4 1.8tqm's Avatar
    Apr 2009
    Edmonds, Wa.
    1,932
    Mike, in your technique, do you lay the terry towel on the pad, place your hand against it applying pressure to absorb excess liquid/residues and let the towel spin with the pad? Or how do you keep the towel from spinning? That's what the above pics make it look like, I imagined wrapping the terry around 2-3 fingers and pressing against the moving pad to breakup the polish/paint buildup. TIA
  1. How Do I Clean My AutoGeek Foam Gun?
    By lovenhim in forum Auto Detailing 101
    Last Post: 06-04-2021, 06:40 AM
  2. Clean foam pads?
    By parshooter in forum Tricks, Tips and Techniques
    Last Post: 12-09-2015, 08:23 AM
  3. Need to clean Foam and Microfiber
    By FD2R SG in forum Auto Detailing 101
    Last Post: 10-02-2013, 09:03 PM
  4. How do YOU clean your foam pads
    By Christopher in forum Auto Detailing Tools and Accessories
    Last Post: 10-06-2011, 07:34 PM
  5. How do you clean wax out of your foam applicator?
    By mcpp66 in forum Ask your detailing questions!
    Last Post: 04-16-2010, 10:43 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
