Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 92
Like Tree1Likes
Thread: How to Mix IPA for Inspecting Correction Results
    Jun 2009
    Stuart, Florida
    37,328
    Re: How to Mix IPA for Inspecting Correction Results
    The goal of this article was to give everyone some information about this popular step and a foundation to build on for any direction you want to go with wiping down paint to inspect it for various reasons.
    I couldn't find a single article anywhere on the Internet for this practice, just recommendations all over the board as it relates to dilution strengths, so this was just an attempt to provide people with a starting point for some basic information.
    Now that it's finished, each person can do their own research and then make-up their own mind as to how they want to proceed. Use 91% straight, or any variation if you determine this is a procedure you want to perform.
    My goal was to provide some information that would provide some level of safety as well as some other options for the procedure including answering some common questions.
    Safety First
    Remember to wear gloves, an chemical resistant apron and safety glasses whenever you're working with chemicals.
    Better safe than sorry...
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
    Senior Member SATracker's Avatar
    Nov 2007
    San Antonio
    582
    GREAT article, Mike...thanks.
  3. #13
    Nov 2007
    San Antonio
    582
    Hey Mike, the reason I thought this was a great article is that I've heard about alcohol wipe downs but never quite understood how it worked. I figured ya just bought a bottle of alcohol and had fun. Your article is very thorough and very well researched. So, thanks.
  4. #14
    Mar 2011
    S.C.S Michigan
    Another great article by Mike! Thanks for taking the time to explain what we are exactly doing to our paint. And more importantly, what the IPA is doing to our paint chemically.
    For those of you like me, who have a few different size spray bottles, here is the math to figure out your total percentage of IPA in your mix.
    X(Y/Z)
    Where
    X= The percentage of your IPA
    Y= Amount of IPA in ounces added to your spray bottle
    Z= Total volume of spray bottle in ounces
    Let's use Mike's formula as an example. 4oz of 91% IPA in a 32oz spray bottle gives us a total percentage of IPA of 11.3%.
    .91(4/32) = .11375 or 11.357%
    So if we were to use a smaller, say 22oz bottle we can now figure out how much IPA to add to achieve our target of 10%.
    .91(3/22) = .12409 or 12.409%
    So, we get 12.4% IPA when we use 3oz of 91% IPA diluted in a 22oz spray bottle.
  5. #15
    Senior Member jpegs13's Avatar
    Oct 2009
    Manhasset, L.I. NY
    1,908
    Let me see if I have this right..
    IPA can be detrimental to the paint and finish.
    Mineral Spirits are volatile and can turn my garage or laundry room into an inferno.
    Now my question(s)
    Would paint cleaner be the safest, most effective method of removing polish residue?
    If so what pad would be used on my DA?
    Thanking in advance.....
    John
    Mean people suck
  6. #16
    Oct 2009
    Manhasset, L.I. NY
    1,908
    somebody help a brother out
    John
    Mean people suck
  7. #17
    Jun 2009
    Stuart, Florida
    37,328
    Hi John,
    Just to comment on your above post point-by-point...
    Quote Originally Posted by jpegs13 View Post
    The problem with IPA is that it can make the surface of the paint soft and then when you wipe the paint your wiping cloth could potentially mar or even scratch the paint. I have a black test panel in the garage right now that I've been testing compounds on and after the tests I wiped the two sections with IPA and a microfiber to inspect the results and you can see straight-line scratches in the direction I wiped off the IPA. They are very fine or shallow but there just the same.
    The hoods in the studio are repaint so they are very different from factory paint and in this case softer, so that could be where the issue lies with this kind of process.
    So IPA works well with compounds and polishes to remove residual polishing oils but with it comes some risk.
    IPA is volatile, in its strongest version, 91% it's probably more volatile than MS
    Used with common sense, you shouldn't have a problem. MS sure wipes easier over paint as compared to IPA
    Now my question(s)
    Yes and no.
    Yes, applying and working a quality paint cleaner over a previously polished surface will act to remove any polishing oils left by the previous product.
    No, because the paint cleaner will leave its own residual polishing oils or "whatever" it is using for a carrying agent(s) and any other ingredients used to suspend the cleaning agents.
    If the goal is to strip the paint free after the last polishing step to leave nothing but a clean or naked base then using a paint cleaner will not accomplish this goal.
    You're back to chemically stripping using,
    • IPA
    • MS
    • Detergent Wash
    • Some other liquid chemical for wiping
    Question: What are you going to use for your LSP?
    For a light paint cleaner, a polishing or finishing foam pad would work, usually you're always working forwards in the process so that would tend to lead you to use a finishing pad.
    IDA Board Member
    CD-SV, RT
    Twitter
    Instagram
  8. #18
    Dec 2010
    610
    Thanks, Mike, for another excellent article. Keep 'em coming.
  9. #19
    Oct 2009
    Manhasset, L.I. NY
    1,908
    Thanks Mike!
    John
    Mean people suck
  10. #20
    Senior Member mc2hill's Avatar
    Feb 2009
    Orlando
    217
    Great article Mike! I have always used and recommended 50/50 IPA, because that what everyone did. Now you have made me think about it more (mostly a good thing!).
    A question (I appologize if you mentioned this in the article) -
    Do you leave the IPA mixture in the bottle after you finish a project or do you mix a new batch each time?
  1. inspecting silver car
    By wdmaccord in forum Auto Detailing 101
    Last Post: 06-29-2013, 07:06 PM
  2. M34 to check final correction results?
    By Zedhead07 in forum Auto Detailing 101
    Last Post: 10-06-2011, 02:48 PM
  3. First Correction - Poor Results - Any Advice?
    By Soulman1980 in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-11-2011, 10:19 PM
  4. Quick Results from Meguair's DA Microfiber Correction System
    By DonMTV in forum Auto Detailing 101
    Last Post: 04-06-2011, 04:17 PM
  5. Interesting results from new Meguiar's Microfiber DA Correction System
    Last Post: 12-03-2010, 04:57 PM
» September 2017
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
