Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Apr 2012
    7,494
    Re: Lake Country Hybrid 3" Pad?
    Quote Originally Posted by Red Hawk View Post
    Kevin Brown, aka Buff Daddy stocks 3" pads, as well as other sizes.
    So does Autogeek and this is their forum
    Lake Country 3 Inch Flat Foam Pads
    2019 Nissan Rogue SL
  2. #22
    Super Member Red Hawk's Avatar
    Nov 2014
    214
    Thanks Custmsprty, I had not seen these on the AG site, so I was unaware they carried them.
  3. #23
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Quote Originally Posted by custmsprty View Post
    Rupes Mini Pads:
    Just to add a note the Rupes Mini pads vs. other guys 3" pads. The Rupes pad being beveled allows you to cut into tight areas more easily than say the 3" pad. The Rupes pad base is 3" but being wider at the surface contact point it is actually better than a 3" pad. It allows you to get in to the tight area while minimizing banging the polisher into say a mirror or tight bumper area. I share this from personal experience. You can also see your work better because of the beveling of the Rupes pad. I'll take the Rupes 4" pad over the other 3" pads all day long.
    Your logic makes good sense. Thanks for sharing this.
  4. #24
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,011
    Quote Originally Posted by fly07sti View Post
    7/8" is pretty low profile. Depending on the machine that they are being used on, you don't have to use any pressure. Just the weight of the machine is more than enough. I use them on my Rupes mini and and my Kompakt and love em.
    I'm always a little lighter handed with Hydrotech pads. They excellent at what they do.
  5. #25
    Aug 2015
    Quote Originally Posted by AGOatemywallet View Post
    Work an area larger than normal
    Swap pads often to let them cool
    Blowing out with compressed air helps cool the pad and BP
    Use your hand to constantly check for heat build-up
    Watch the amount of downward pressure. Remember it is focused on a much smaller are than a 5" pad
    More likely to "twist" paint than "burn" it
    Sweet, thanks for the tidbit AGO!
  6. #26
    Aug 2015
    Rupes Mini Pads:
    This and your previous quote regarding tearing up of "other" pads has been very insightful. I'll have to start seriously looking into the whole Rupes line. Thanks Custm!
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Lake Country Hybrid Yellow ????
    By SonOfOC in forum Auto Detailing 101
    Last Post: 05-01-2016, 03:22 PM
  3. Lake Country Hybrid
    By Lustrous Detail in forum Flex Polishers
    Last Post: 07-30-2015, 07:51 PM
  4. Lake Country Hybrid vs. Flat Pad
    By expdetailing in forum Auto Detailing Tools and Accessories
    Last Post: 09-25-2014, 09:47 PM
  5. Mini-Review: Lake Country 5" Hybrid Pads
    By erichaley in forum Product Reviews
    Last Post: 06-18-2013, 08:03 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
