Results 1 to 7 of 7
    Member Smurf's Avatar
    Nov 2011
    Cambridge New Zealand
    74
    What are your thoughts ?? ( Pads )
    I have been using Meguiar's W7006,W8006 & W9006 pads for a long and with exellent results.
    My question is
    If I was to try another pad what would be the best out of the 3 types to try Meguiars,Lake country's CCS or Chemical Guys Pads.
    The reason being a detailing shop has just brought in Lake country And Chemical Guys Pads. Do you stick with the devil you no or try something new ?
    Lake country's CCS range
    Lake Country Gold Concours Pad
    Lake Country Green Heavy Polishing Pad
    Lake Country Yellow Cutting Pad
    Lake Country Orange Light Cutting Pad
    Lake Country Red Finishing Pad
    Lake Country White Light Polishing Pad
    Chemical Guys
    Chemical Guys 6.5" Hex-Logic Yellow Heavy Cutting Pad
    Chemical Guys 6.5" Hex-Logic White Medium Polishing Pad
    Chemical Guys 6.5" Hex-Logic Orange Medium Cutting Pad
    Chemical Guys 6.5" Hex-Logic Green Heavy Polishing Pad
    Chemical Guys 6.5" Hex-Logic Blue Soft Polishing / Finishing
    Chemical Guys 6.5" Hex-Logic Black Finishing Pad
    What are your thought???
    SWIRL FREE POLISHING
    Take Pride In Your Ride
    Senior Member Porsche Pilot's Avatar
    Jun 2010
    Florida
    1,745
    Re: What are your thoughts ?? ( Pads )
    I haven't used the CG's pads but can say that Lake Country makes outstanding pads. Personally, I prefer the hydrotech pads and absolutely love them. Eric Dunn of Lake Country twisted my arm at Detail Fest and I picked up the new hybrid power finish pads. A quick test with those last night and I am in love.
    ED aka Porsche Pilot
    Senior Member Impressions's Avatar
    Oct 2009
    palm city florida
    583
    I agree with Ed, Hydro-techs have been my go to pad, but since using the new hybrid pads I gonna stock up
    Robert DiTerlizzi, 772-260-6636
    Impressions Fine Automotive Detailing
    7782 SW Jack James Dr.Stuart, Fl.
    Senior Member Mike@DedicatedPerfection's Avatar
    Feb 2011
    Germany
    11,802
    I am in the same boat as you. I have been using the Megs line for a while but wanted to try something new and just put in a order for HT pads in 5.5 diameter. Cant way to try them out.
    Nov 2011
    74
    Quote Originally Posted by Porsche Pilot View Post
    All the shop has got is the CCS pads not the hybrid are they worth a go?,if so what colours would I need to get ?
    Jun 2010
    Florida
    1,745
    The CCS pads will work great for you. I like to get several of each if you can. Orange, White, Black and Blue (or red) are my basics and are "typically" used in that order for correction. Of course, always start with the least aggressive method.
    Aug 2011
    The "OC"
    883
    If you can wait, I would pass on the CCS. I love all the LC pads except the CCS.
    The CCS were designed with DA polishers in mind. They designed it to reduce heat and friction by putting in those dimples. This helped the weaker Porter DAs.
    However, the dimples take away, IMO, a signicant amount of surface area. Sure enough pressure would push those dimples flat, but I've never been able to get a CCS pad to cut or polish as effectively when compared to the LC flats or HT.
    The new LC Hybrids that have gotten great reviews are also "flat".
    As for the CG Hex, they are made by B&S. They use the honeycomb hex pattern. CG orange and white pads are very durable.
    May want to try LC Tangerine and Crimson for polishing and finishing.
    MF for cutting.
    There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
  1. TurboBuff Buffing Pads - What are your thoughts...
    By buick_gn in forum Auto Detailing 101
    Last Post: 04-02-2015, 06:25 AM
  2. My thoughts on the micro fiber pads and a flex 3401
    Last Post: 09-19-2012, 08:55 PM
  3. Melted CCS Pads? Thoughts?
    By lokerola in forum Ask Mike Phillips your detailing questions!
    Last Post: 06-20-2012, 09:50 PM
  4. Melted CCS Pads? Thoughts?
    Last Post: 06-19-2012, 06:29 PM
  5. Thoughts on LC kompressor pads??
    By 93fox in forum Ask Mike Phillips your detailing questions!
    Last Post: 01-12-2011, 01:10 AM
» February 2017
293031 1 2 3 4
26 27 28 1234
