Results 11 to 20 of 26
    Senior Member MonoPed's Avatar
    Nov 2010
    Hernando, FL
    163
    Re: 3.5" Backing Plates and 4" Spot Repair Pads on DA Polishers
    Do the smaller plates and pads throw the PC7424xp out of balance and make it vibrate more? Also, are there regular low profile/flat pads available in 4"?
    Brian Fowler, Hernando, FL
    2008 Mustang Pony Package
    Jan 2011
    833
    Quote Originally Posted by BobbyG View Post
    Because it's a mechanically driven backup plate the gear size plays a major role in its design...
    If no one makes one I'm just gonna buy up some extra factory replacement backing plates for the Flex and just custom trim it or something so that I am retaining the mechanical end of it. I'm sure you can figure something out and test it on some junkyard panels. I am shocked at the low support for this awesome machine. If I had the resources there are lots of different design ideas that could be easily manufactured.
  3. #13
    May 2011
    307
    how does the meguiars 3 inch backplate compare to the lake country 4 inch?
  4. #14
    Senior Member Danube's Avatar
    Jan 2012
    Australia
    864
    Quote Originally Posted by qaz393 View Post
    I've been using megs 3" BP with megs 4" pads.
    IMO this is perfect combo, and its really good for machines such as G110/G220, GG and the like.
    I found that 6" BP with 7" pad is an overkill for the DA. The lack of power is then more then obvious.
    Flex 3401 & PE14
  5. #15
    Thanks Mike for info,
    Will this pad work with rotary polisher? I am asking because they will be very handy on bikes.
  6. #16
    Jan 2012
    248
    Are the four inch pads small enough to take care of most tight areas on a 2011 Mustang? I'm thinking "yes", but would like to see if anybody else has used them before buying.
  7. #17
    Jun 2009
    Stuart, Florida
    36,212
    Quote Originally Posted by surajprasade View Post
    Yes, I use 4" pads on rotary buffers all the time.
    Quote Originally Posted by Mustang81 View Post
    Yes, most of the tight areas can be handled using a 4" pad. If not then there's always these,
    Surgical Buffing
    Working on thin panels or intricate areas is what I call surgical buffing. In order to do surgical buffing you need the right tools.
    We have these new 3" pads and together with a 3" backing plate and an adapter for using double side pads but I use them as an extension.
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  8. #18
    I purchased the 4" LC pads with a 3.5" backing plate for small areas on my 90 mustang GT.Areas like around the antenna,5.0 emblem and anywhere tight.The pads are should be here by Tuesday or Wednesday next week.I'll post some pics of the new pads and area to be buffed along with the results.
  9. #19
    Here are a few pictures of the pads I got from auto geek.The pads are 4" lake country ccs pads with a 3.5" backing plate.I used Meg's 105 with a yellow 4"ccs pad.I used a PC 7424xp to do the work.I made 6 section passes,the wiped it off to see what the results were.The scratch was still there,but barely.I made another 6 section pass and it removed the entire scratch.Next I followed it with Meg's 205 and a white 4" ccs pad.The results were awesome!
  10. #20
    Senior Member sproketser's Avatar
    Aug 2012
    Qc . Canada
    2,660
    Thanx for sharing , might be handy one day !
  1. 1" and 2" Backing Plates for DA?
    By dmayer in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 04-15-2015, 02:52 PM
  2. Flexible Rotary Buffer Backing Plates for the 6.5" Hybrid Pads
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 06-04-2014, 10:50 AM
  3. New 4" and 6" Backing Plates for Flex 3401
    By Mike Phillips in forum New Car Care Products
    Last Post: 04-23-2012, 03:26 PM
  4. 5" and 6" Backing Plates on 6.5" pads (Pictures to show safety margin)
    By Mike Phillips in forum Hot topics & Frequently Asked Questions
    Last Post: 08-31-2011, 07:48 AM
  5. Spot Repair Backing Plates and Buffing Pads
    Last Post: 02-13-2010, 02:32 AM
» April 2017
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
