Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Wool & Foam Buffing Pads
» Autogeek Online Classes
Reply
Thread Tools Display Modes
Old 02-23-2010, 05:09 PM   #1
Director of Training
Mike.Phillips@Autogeek's Avatar
Using a 4" Spot Repair Kit to Remove Paint Defects
It's important to remember that with a small foam pad you're going to bring a lot of cleaning and abrading action down to a very small sized area and this means it's very likely that it won't take long to remove enough paint off the surface to level the surface and thus remove the defect.
So focus on the task at hand!
In most cases you're going to need a compound, paint cleaner, swirl mark remover or medium aggressive polish and either a polishing pad or a cutting pad for your first buffing step, always follow the philosophy of use the least aggressive product to get the job done and do some testing.
DA Polishers
Porter Cable 7424XP
Meguiar's Dual Action Polisher G110v2
Griot's Garage 6" Random Orbital Polisher
Griot's Garage 3" Mini Polisher
Rotary Buffers
FLEX L3403 VRG Lightweight Circular Polisher
Makita 9227C Polisher
FLEX LK603VVB Circular Polisher
Dewalt 849 Variable Speed Polisher
Dual Head Orbital Polisher
Cyclo Orbital Polisher
CCS Spot Buffs 4 Inch Foam Pad Kit
What's in the box?
2 each 4" CCS Orange Light Cut Pads
2 each 4" CCS White Polishing pads
1 each 4" CCS Blue Pad
1 each 4" CCS Gray Pad
1 each 2 7/8" Rotary Buffer Backing Plate
1 each Rotary Buffer to DA Polisher Adapter
1 each Rotary Buffer to Drill Adapter
2 each Cobra Blue Microfiber Polishing Towels
1 each Cobra Quick Clenz Pad Cleaner
Quote:
Warning
When using the adapter to connect the backing plate to a DA Polisher note that
it's possible to get your finger next to the counterweight while it's spinning, so
use a safe grip on the tool and keep your fingers away from the inside of the housing where
the counterweight is located. I've included some pictures below to drive this point home.
Single Head Dual Action Polishers
Porter Cable 7424XP
Meguiars Dual Action Polisher G110v2
3" Spot Repair Pads
Griot's Garage 3 Inch Orange Polishing Foam Pad 3 Pack
Griot's Garage 3 Inch Mini Red Wax Pad
Griot's Garage Professional Random Orbital 3 Inch Polisher
Griot's Garage 3 Inch Mini Red Wax Pad 3 Pack
Rotary Buffers
Mike.Phillips@Autogeek is online now
Old 05-18-2011, 10:10 AM   #2
Re: Using a 4" Spot Repair Kit to Remove Paint Defects
Can you use the Griots 3" pads with the 2-7/8 backing plate included in this kit? Will it have enough safety margin? I would like to be able to use my PC with the 3" pads and avoid buying a mini polisher.
Birddog is offline
Old 05-18-2011, 10:47 AM   #3
Quote:
Yes. I use them all the time with rotary buffers. See this thread for pictures...
Pictures + Video of 1932 Ford Highboy Extreme Makeover
Great question...
Old 05-18-2011, 10:59 AM   #4
james_death's Avatar
Nicely done, certainly more cut from the smaller pad..
james_death is offline
Old 05-18-2011, 09:07 PM   #5
MonoPed's Avatar
Why are the 4" pads CCS only? Why not flat or low profile flats?
__________________
Brian Fowler, Hernando, FL
2008 Mustang Pony Package
MonoPed is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Removing Orange Peel & Sanding Marks with the Griot's ROP and the Wolfgang Twins Mike.Phillips@Autogeek Wet-Sanding, Cutting & Buffing 45 08-30-2011 04:41 PM
Back to the basics- Detailing diagrams and Dialog budman3 Tricks, Tips and Techniques 29 08-15-2011 07:09 PM
Decsions, decisions: 7424XP kit & XMT 360 questions MisterShark Ask the Expert featuring Mike Phillips 10 09-08-2009 08:53 AM
» May 2012
2930 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
» Car Care Brands
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
