Page 4 of 4 FirstFirst 1234
Results 31 to 33 of 33
Like Tree9Likes
Thread: rupes 21 destroyed some good quality pads
  1. #31
    Jul 2013
    Apex, NC
    371
    Re: rupes 21 destroyed some good quality pads
    Work smaller areas and slower arm movement to let the polisher do the work. You are consistently lifting the handle end of the polisher forcing the front down into the paint. I know you think you are keeping it flat, we all do. Flat front to back and also side to side. X and Y axis.
    I have a buddy that helps me sometimes and its a struggle to get him to slow down his arms. He thinks he is adding to the polisher's movement. He never seems to work the polish evenly because of all the movement.
  2. #32
    From the VDO I am clearly see that you put a little too much pressure and the machine showing some stall as well. Adjust the pressure let it spin.
    dlc95 likes this.
  3. #33
    Senior Member Mantilgh's Avatar
    Dec 2014
    Boonsboro, Md
    1,914
    The thing I noticed is that your working section is huge, 1/2 of the hood.
    Quote Originally Posted by Todd@RUPES View Post
    The combination of a lubricant that has lost efficiency and a slurry that has more solid content mean your results are going to suffer. You are also inducing more drag at the foam/paint interface which means the pad is flexing more and heating up. The longer you work it, the more the problems increase and internal temperature of the pad goes through the roof.
    ^What Todd from Rupes says.
    ____________
  1. Rupes 21 MK II Unboxing (Very High Quality!)
    By RFLCT in forum RUPES BigFoot Oribital Polishers
    Last Post: 10-07-2016, 04:20 PM
  2. How do you know if a MF towel is of good quality?
    By fastfurious23 in forum Auto Detailing 101
    Last Post: 09-16-2014, 12:14 AM
  3. Good quality car shampoo...
    By Lexi65 in forum Auto Detailing 101
    Last Post: 02-21-2014, 10:40 PM
  4. pads destroyed
    By SPIROS ANTONIOU in forum Auto Detailing 101
    Last Post: 05-22-2012, 06:16 AM
  5. Replies: 7
    Last Post: 03-15-2012, 08:56 AM
» February 2017
293031 1 2 3 4
26 27 28 1234
