Results 11 to 20 of 40
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    4,777
    Re: rupes 21 destroyed some good quality pads
    With the Rupes you don't need pressure. 5 to 6 passes with the Rupes liquids is all that is needed to break them down.
    Senior Member Bigry18's Avatar
    Dec 2012
    Lancaster CA
    366
    My guess is too much pressure? I had similar issues but just went over it some more if i needed more correction.
  3. #13
    Senior Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    4,090
    Is the middle yellow pad, a Rupes pad?
  4. #14
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Too long of a buffing cycle with too much pressure. Saw a pal do the exact same thing with a PC.
  5. #15
    Member
    Aug 2015
    38
    Quote Originally Posted by GSKR View Post
    I can tell by the pads there overused.I use pads till they die.constantly buying pads all the time.
    Do you mean overused in "use it for too many cars/years atc" or overuse on "too much time for a buffing cycle" ? The only pad that have some "mileage" on is the white spider pad.
    Sent from my E5823 using Tapatalk
  6. #16
    Member
    Aug 2015
    38
    I am adding a video, it's me working on the rupes with a rupes pad. Maybe it can put some light on my technique. It's in hebrew (for my costumers in israel) but everything else is universal.. What do you think about the technique? The result is in the second part of the video. I will be happy for your opinion on the results 2..
    https://youtu.be/NE0U1l8hIq8
  7. #17
    Jul 2016
    1,991
    how do u clean the pad? maybe thats it
  8. #18
    Jul 2016
    1,991
    Quote Originally Posted by aderet View Post
    are those pads on the ground supposed to be clean, they look rough
  9. #19
    Member
    Aug 2015
    38
    The pads on the floor where on their way to be wash, the pass that was on the video was the last one for the job . I never use a dirty pads and i clean them every 1-2 buffing cycles with air and after ~10~ cycles with APC and move to a fresh pad.
  10. #20
    Sep 2015
    6,276
    They just look tired,and from experience I've been there many times.pads don't last forever the apc could be eating them up.I use gentle soap with cold water.Try the thin pro pads since trying those out haven't had any issues just with the thicker bigger pads.Thin pros are easier for maximum rotation and easier to clean.
  1. Rupes 21 MK II Unboxing (Very High Quality!)
    By RFLCT in forum RUPES BigFoot Oribital Polishers
    Last Post: 10-07-2016, 04:20 PM
  2. How do you know if a MF towel is of good quality?
    By fastfurious23 in forum Auto Detailing 101
    Last Post: 09-16-2014, 12:14 AM
  3. Good quality car shampoo...
    By Lexi65 in forum Auto Detailing 101
    Last Post: 02-21-2014, 10:40 PM
  4. pads destroyed
    By SPIROS ANTONIOU in forum Auto Detailing 101
    Last Post: 05-22-2012, 06:16 AM
  5. Replies: 7
    Last Post: 03-15-2012, 08:56 AM
» January 2018
28 29 30 31 123
