Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Feb 2015
    Ft. Lauderdale,Fl
    361
    Re: First time wet sanding kit - #3000 & #5000 Trizact Sanding Discs
    I want to try them on stainless before mirror polishing.
  2. #22
    Member
    Aug 2016
    Howell, Mi
    75
    I obviously meant filtered water rathe than IPA. My apologies.
  3. #23
    Member
    Aug 2016
    Howell, Mi
    75
    Learning something new every day. I have finished my damp sanding test and have some pretty interesting 'finds'. One thing that helps a ton is using a interface pad with holes. The holes help reduce heat and also to have a thick back up pad with holes as well. Great comments on Trizact. Great product as well. In my 'find' i did not use Trizact though.
  1. Rupes 5 Inch 2000 & 3000 Grit Sanding Discs
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-30-2016, 03:48 PM
  2. 3™ Trizact™ Foam Discs 5000 FAQs
    By Mike Phillips in forum Wet-Sanding, Cutting & Buffing
    Last Post: 11-30-2016, 01:54 PM
  3. Video: Wow! 3M #5000 Grit Polishing I mean Sanding Discs!
    Last Post: 01-16-2015, 07:20 AM
  4. 3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459 - Singles
    Last Post: 05-22-2012, 11:16 AM
  5. Replies: 0
    Last Post: 01-29-2010, 11:22 PM
» February 2017
293031 1 2 3 4
26 27 28 1234
