Re: HD adapt Hologoram/Marring
GG6 on 6. Ok slower and softer pads.
Originally Posted by allenk4
Is Subaru White Paint BC/CC or single stage?
soft "sticky" bc/cc, typically
HD Adapt.......White pad......and play with the hand pressure on the machine and done. That Orange pad is causing the marring. I've used the same combo numerous times with great results.
trying some blue pads w hdadapt. i wasn't sure if i should've gone with green but we'll see how that turns out. got myself a small bottle of cut and polish too so we'll see how that works. thanks for all the response guys i'll definitely look into some white pads and try wool pads in the future
Wool would be going to be the most agressive, that is if that machine can spin them.
What pads do you have on hand?
right now i have yellow and orange cutting foam pads.
i just picked up some hydrotech cyans
i went on 3d and bought some blue finishing pads just yesterday. so i'm going to try those with the HD adapt.
what kind of white pads should i buy? i heard the green ones are good but i forgot from what company. i know wool is only for cutting. i'm more about removing scratches swirls and paint correction.
I believe the pads from HD are made by buff & shine. If that's true, it will be the same foam composition as the green hex logic, which is usually my initial compounding pad. This means that the blue HD pad will feature the same foam as the blue hex logic, which is my normal polishing pad. The blue has the slightest amount of bite to it, which will aid the abrasives in accomplishing their refining task.
My car has soft paint, and the blue hex, and ultimate polish on the pc (speed 5) did a good job cleaning up the paint. In lake country's line up, their green ccs would be the closest.
The green hex logic / hd (assuming both are made by b&s) pad is considered "light cutting / heavy polishing", and offers a very nice blend of cut and finish. In lake country's line up, the pink ccs would be the closest. This pad features a fairly porous, open cell design, and I find that excessive priming used on other pads only hyper saturates these open cell, porous pads, reducing the cutting ability. I use about five small drops of product to start with, then about three per section pass, depending on size of area to be worked. These pads also don't require the pressure I would use on say an orange hex logic, or ccs pad.
I approach the blue pad in the same manner.
If I need more cut, I use microfiber. I can wipe out 1000 grit with m105, and a blue rupes cutting disc on my pc if I have to. You can check out the pics in my album if you want.
Adapt should work fine here. Use speed 3-4, and shrink down your work area significantly. I stay with 12-18" square, and make 7-8 passes. Adapt has a very long work cycle if you use it correctly - and you need to run it for awhile in order for the oils to properly breakdown.
what colors of the CCS should i buy? Hex's they dont sell on AG unless they really really sold out or never stocked them.
i was thinking of getting:
sealant: red
polish: white
(i have enough cutting pads to go through)
HD adapt: pink ccs
HD cut: (already have enough)
what about HD polish? white should be good or should i go with green?
what are your thoughts on waffles vs hex?
By 2011 Kona Blue in forum Product Reviews
Last Post: 08-26-2016, 02:24 PM
Last Post: 08-16-2016, 10:59 AM
By gordster1122 in forum Auto Detailing 101
Last Post: 04-09-2016, 06:34 AM
By bossmustang16 in forum Auto Detailing 101
Last Post: 02-15-2015, 10:17 PM
By SC sid in forum Auto Detailing 101
Last Post: 01-30-2012, 07:43 AM
