Wetsanded a little too much
Hi everyone,
I've spent all this afternoon wetsanding back all my touchup areas applied to stone chips on the front of my daily driver (Applied last weekend). After removing the wetsanding marks with Meguiars Ultimate Compound, I noticed that a few areas I must have wetsanded too deep as it seems for lack of a better word, divoted.
Everything is ok with the paint color however, whilst compounding, I noticed the reflection isnt level, as if I've wetsanded too deep in a few spots, creating a 'divot' in the clearcoat. The only way I can really describe it is similar to hail damage.
Is there a way to level the clearcoat myself or is it going to be one of those 'respray or make do' situations?
I apologise for lack of photos but it's too dark to get a good picture.
Re: Wetsanded a little too much
Did you wetsanded your ride ! If you went too far then you ll need to have that section done by a pro painter .
If not , some will be able to help you out in here .
Saying you wet sanded a little too much is like saying a girl is a little bit pregnant. You need a repaint.
Thanks Bobby, did alot of research here before jumping in and now I'm hooked.
I think deep down I knew a respray was the only solution but was hoping to avoid that. It doesn't look like I've gone all the way through the clear as no color appeared when compounding so since it's the daily driver it's probably not worth doing.
I guess the only comfort for me is that it doesn't stand out as much as the dozens of stone chips that were touched up.
PAHAHAHAHAHA Made my entire week...
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government" Thomas Jefferson,
LoL!!
opti coat2 and let it find its own leavel drop or two will work .
Short of a repaint, you won't be able to remove them unless you sand the surrounding areas down to the same level, which is a bad idea. I'm sure others may disagree, but one possible option you may have is trying to blend or soften the edges of the "divots" so that they are less visible. I can't say that I'd recommend it, but its an option...
2013 Honda Accord Touring - Crystal Black Pearl/Black
Originally Posted by johnny_abardi
Hi everyone,
What grade of paper and what machine did you use? It might just be that you need a less aggresive paper or a stronger machine
Anyway for ?
By 6LS2 in forum Show N' Shine
Last Post: 09-03-2018, 05:27 PM
By DetailedByPrecision in forum Show N' Shine
Last Post: 04-06-2016, 05:48 AM
By builthatch in forum Auto Detailing 101
Last Post: 07-26-2014, 01:59 PM
By rackfiller in forum Show N' Shine
Last Post: 05-15-2013, 11:45 PM
By The Count in forum Auto Detailing 101
Last Post: 09-27-2011, 07:58 AM
