Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Wet-Sanding, Cutting & Buffing
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 09-15-2011, 11:21 AM   #1
Member
Cool Hand or machine...
color sanding,whats your prefered method?
Dan
Dan C is offline
Old 09-15-2011, 11:46 AM   #2
BobbyG's Avatar
Re: Hand or machine...
Hi Dan,
Back in the day all wet sanding was done manually with various rubber pads and blocks to distribute the pressure evenly.
I watched Mike's video on damp saning and while it appears to be perfectly logical I've never tried it. Perhaps this is more the norm these days so lets hope someone in the paint trade chimes in..
__________________
BobbyG is offline
Old 09-18-2011, 08:46 PM   #3
Hey Dan,
I work in a body shop and do a good amount of wet sanding to fix minor issues after the paint job has come on. It really depends on how big of a defect you have and how big the area is that you are working with. Personally, I prefer doing it by hand because I feel like I am able to better control how much I take off.
azhun_ctech is offline
Old 09-18-2011, 09:34 PM   #4
Flash Gordon's Avatar
I would rather sand by hand. I get a better feeling for whats actually taking place. With a machine, there is so much noise, and at times the machine gets in the way visually
I am a bit of a noob to this, but for now using a sanding block is my perferred method. I charge by the hour, so time is not an issue for me personally
Flash Gordon is offline
Old 09-19-2011, 08:03 PM   #5
Member
I also prefer to do it by hand because you have all the control. In machine sometimes you can't control you take off....
4wheelsonline is offline
Old 09-23-2011, 12:07 AM   #6
Member
Thanks for the replys guys!
Dan
Dan C is offline
Old 09-23-2011, 12:37 AM   #7
PorscheGuy997's Avatar
As with almost everything in detailing, the answer depends on a number of things.
If you want the flattest finish possible, try sanding by hand. There are also times when an interface pad just isn't going to contour to the surface like a hand pad and sheet of paper.
I really like DA sanding. It's not as strenuous as hand sanding and the results are very close. The latest DA disks are getting better and better at leveling the surface. The time it takes to DA sand a car is much less, too.
Both types of sanding will have their drawbacks. DA disks can produce tracers, while hand sanding can produce tracers.
Sanding is one of those skills that can not be acquired over night. With enough experience, one can learn how to minimize the drawbacks, while producing a better finish.
__________________
Chris
PorscheGuy997 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
» June 2013
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
» Car Care Brands
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
